Leafs and Caltracs or ladders? #1540078
11/26/13 12:47 PM
11/26/13 12:47 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
As I keep turning up the boost I can't help but notice that my 40yr old springs are starting to loose their bounce. I've lost ride height on the pass. side and even with the rear sway bar preloaded, the body still rolls alittle to that side. My question is, from a cost and streetablilty standpoint, which would be the best route to go, caltracs and new leafs or ladder bars? This car is 90% street but is driven hard an sees alot of stoplight challenges
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540079
11/26/13 12:57 PM
11/26/13 12:57 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Street ability I would go with leaf springs and caltrac's. But for the race stand point a ladder bar is going to be a better overall for you. IMO. I don't have a problem driving a 4 link strut car with a big cid engine and a dominator on the street. Everyone has a different level of what they think a "street" car is. It I were in your shoes I would put ladder bars and an anti roll bar on it with some good coil over double adjustable shocks.
Back in the swing of things at Painless again! Great to be back!
Re: Leafs and Caltracs or ladders? [Re: BJS racing] #1540080
11/26/13 01:06 PM
11/26/13 01:06 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I'm in the same boat, I would drive a tube car on the street lol. The ride quality now sucks anyway because of how low I've got it sitting. Price wise they both seem to look about the same too. The advantage of ladderbars too is I can adjust ride height at any time.
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540081
11/26/13 01:16 PM
11/26/13 01:16 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I would also run a wish bone and not a diaganol/track locator. It will help keep the ladder bar and brackets from binding as you go in and out of drive ways and what not.
Re: Leafs and Caltracs or ladders? [Re: BJS racing] #1540082
11/26/13 01:26 PM
11/26/13 01:26 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Good to know thanks! My buddy had a wishbone that came off a nova drag car I'll have to see if he still has it around.
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540083
11/26/13 01:32 PM
11/26/13 01:32 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Heck if you are going to do all that work why don't you just put a 4 link in it?
Re: Leafs and Caltracs or ladders? [Re: BJS racing] #1540084
11/26/13 01:42 PM
11/26/13 01:42 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I could but even when I get done I'll probably still be under 600hp anyway and I don't race enough to need the tuneability of a four link. Plus I would need alot of help getting the 4 link not to send me into the wall
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540085
11/26/13 01:46 PM
11/26/13 01:46 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
You can get a 4 link to act just like a ladder bar with the right adjustment. typically you can set one neutral with an anti roll bar in the system and drive it on the street and then run it at the track. There is always a happy medium that you can adjust to. I know guys that have a "street setting" and when they get to the track they get under the car and use their "race" setting. Once you figure out what it likes you really wouldn't spend much time changing it back and forth. Or set it in one place and go with it. No matter what you go with try to keep out of putting preload in the suspension. Preload is bind on the system.
Re: Leafs and Caltracs or ladders? [Re: BJS racing] #1540086
11/26/13 01:59 PM
11/26/13 01:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I left mine on leafs & add cal-tracs. Also added an anti roll bar. Cars are in the 6's now over 200MPH on leafs. It can be done, just needs alot more tuning.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Leafs and Caltracs or ladders? [Re: 6PKRTSE] #1540087
11/26/13 02:01 PM
11/26/13 02:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Going with boost someday with mine also.
Re: Leafs and Caltracs or ladders? [Re: BJS racing] #1540088
11/26/13 03:36 PM
11/26/13 03:36 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Correct me if I am wrong but don't most ladder bars comes with solid rod ends, not heim joints like a 4 link? And if they are solid ends, why would you need the wish bone? With the solid rod ends the rear won't pitch rotate, no? I'd agree that with heim joints you could benefit from a wish bone but with solid ends wouldn't a diagonal link be all you need?
Re: Leafs and Caltracs or ladders? [Re: Sixpak] #1540089
11/26/13 03:37 PM
11/26/13 03:37 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Mine has hiems on it all !
Re: Leafs and Caltracs or ladders? [Re: Sixpak] #1540090
11/26/13 04:20 PM
11/26/13 04:20 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
and if you get the car side ways at all how much load is on those solid rodends? The fronts you should never run a solid joint. There is too much stress and articulation going on in that area. The rear on the housing is ok with them but on the front you really should run a good quality heim. Some of the kits come with all solid. That is for the cost effectiveness to the manufacturer. It doesn't mean its the best thing for the customer.
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540091
11/26/13 04:34 PM
11/26/13 04:34 PM
My Duster had 1/4 Max ladder bars with a diagonal link andStrange single adjustable coil overs. that combination work well on a good track, not so on a bad track or on the street all the time I ended up switching them to double adjustable and that was worth doing to start with Buy the good double adjustables ones to start with My car had 170 lb springs on the back, the double adjustables I bought came with 150 lb springs, that road better on the street My car weighed 3450 lbs wet with me in it. I did buy the longest travel ones that Strange offer at that time, 16.5 inches extended, that gave me about sevin inches fo travel stop to stop IHTHsBTw, that car will hook in a mud puddle in the middle of a rain storm 1.39 60 fts. on ET Street Radials I had the front hiem joint in the lowest hole with no preload on the bars, the car went straight and was easy to drive
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540092
11/26/13 04:36 PM
11/26/13 04:36 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I'd keep the weak springs and add Caltracs and a good shock...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Leafs and Caltracs or ladders? [Re: Eric] #1540093
11/27/13 12:26 AM
11/27/13 12:26 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Do you think the old springs are a safety item?
Re: Leafs and Caltracs or ladders? [Re: SLOW67] #1540094
11/27/13 02:39 AM
11/27/13 02:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm staying with the cal-trac mono split spring and now in search mode for that "good shock"
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Leafs and Caltracs or ladders? [Re: Sixpak] #1540095
11/27/13 02:57 AM
11/27/13 02:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With just solid rod ends you will bend those front
mounts if you go into any corner fairly hard... there
is enough side load and leverage to bend them and
then the tire is into the fender... you need a lateral
bar of some type... I have ladder bars in my Rampage
with a diagonal link(I've used this set up in multiple
street cars)... one thing for the street... you should
brace the lower ladder bar mount near the hole where the
diagonal bar mounts... otherwise it will flex and break
If you want a real nice set up for the street.. run
a Watts Link
Re: Leafs and Caltracs or ladders? [Re: MR_P_BODY] #1540096
11/27/13 08:36 AM
11/27/13 08:36 AM
gregsdart Offline
gregsdart  Offline
a Watts Link
To add one thing to what Mike suggests, be sure and box the rear brackets on the rear end housing. If you get the car sideways, they can lay over and cause issues.
Re: Leafs and Caltracs or ladders? [Re: gregsdart] #1540097
11/27/13 01:23 PM
11/27/13 01:23 PM
fresno ca
mikeysmopars Offline
fresno ca
a Watts Link
Wow!! Gonna run out & take another look at mine.
Mine is race only but Like a buddy told me "Ladder Bar It & Be Done With It" Mine now is very consistant
Founder and CEO of the Central Valley Mopar Drag Pack
