Which center sect 742 or 489?? #1540005
11/26/13 04:42 AM
11/26/13 04:42 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
I recently purchased a started project....
8 3/4 rear from supposedly truck was narrowed & axles as well
need center sect unit???? Which one should I seek?
Plan on using 727 hooked up to 360 (1977 old camper mtr)
in my 37 truck. Posi would be great. I measured axle shafts dia and got 1.5" approx?
just do not know which way should go?
Re: Which center sect 742 or 489?? [Re: 36dodge] #1540006
11/26/13 04:51 AM
11/26/13 04:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
The 742 is stronger than the 489 cases are stock, if you replace the crush sleeve in the 489 it will last a lot longer under abuse than it will stock. It will still not be as strong as the 742 is due to the differences in the sizes of the front pinion bearing and the diamerter of the pinion gear shaft where the front pinion bearing rides
Re: Which center sect 742 or 489?? [Re: Cab_Burge] #1540007
11/26/13 09:33 AM
11/26/13 09:33 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
ANY 8.75 case will work, they all have the same spline count/axel shaft size, unless they have been modified.
Re: Which center sect 742 or 489?? [Re: 65rbdodge] #1540008
11/26/13 12:11 PM
11/26/13 12:11 PM
dogdays Offline
dogdays  Offline
For a 360 in a light pickup it doesn't matter. Any 8 3/4 center will do the trick.
I'd pick in this order:
1. Ratio
2. Sure Grip or not
3. Case casting number
If you're talking about a limited sip differential in a Chrysler Corp car, their trade name is Sure Grip.
Positraction is a General Motors trade name.
Mopar people get bent out of shape pretty easily if you use the GM term. Another example is "broadcast sheet" which in GM-speak is "build sheet"
It's kind of fun to learn and use the correct terms because it's like the club secret handshake.
R.
Re: Which center sect 742 or 489?? [Re: 36dodge] #1540009
11/30/13 04:37 PM
11/30/13 04:37 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Don't let anyone BS you into thinking a 741 case won't hold up. I have run dozens of them behind mild 440's, run them hard and never had one fail. The factory used them behind Max-Wedges. With a small-block, any of the cases should hold without a problem.
Re: Which center sect 742 or 489?? [Re: elmor353] #1540010
11/30/13 05:23 PM
11/30/13 05:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
There is nothing wrong with a 741 case, but the factory never installed one in a Max Wedge car.
Re: Which center sect 742 or 489?? [Re: DoctorDiff] #1540011
11/30/13 06:35 PM
11/30/13 06:35 PM
E
elmor353 Offline
elmor353  Offline
E
Really? What did they put behind max-wedges? I read that they used 741's, but I know what you do for a living, so I won't argue! lol
Re: Which center sect 742 or 489?? [Re: elmor353] #1540012
11/30/13 08:51 PM
11/30/13 08:51 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
Just purchased a 742 case...on its way
still seeking internals??
Re: Which center sect 742 or 489?? [Re: 36dodge] #1540013
11/30/13 09:00 PM
11/30/13 09:00 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
any 8 3/4 as long as you don't plan on alot of HP and hooking up....burning rubber won't hurt any.......to a point
Re: Which center sect 742 or 489?? [Re: elmor353] #1540014
11/30/13 09:47 PM
11/30/13 09:47 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Max Wedge cars came originally came with 742 castings.
Re: Which center sect 742 or 489?? [Re: DoctorDiff] #1540015
11/30/13 11:28 PM
11/30/13 11:28 PM
I'd get a good used clutch (741/742) sure grip pig in the ratio you want & throw it in there. I twisted the pinion splines on a 741 behind a circle track 360 but in your app you wont have a problem with a 741.
Re: Which center sect 742 or 489?? [Re: DoctorDiff] #1540016
12/01/13 03:35 AM
12/01/13 03:35 AM
Both of my 1963 M.W. Belevederes had 742 cases in them with the early tapered type axles
Re: Which center sect 742 or 489?? [Re: Cab_Burge] #1540017
12/02/13 01:14 PM
12/02/13 01:14 PM
dogdays Offline
dogdays  Offline
www.doctordiff.com
Is the place to get internals. I'd vote for a TruTrack limited slip and whatever gears you want to live with.
Heck, ship him the case and get it assembled. It's worth the cost to have it done right.
R.
