71' Hemi Coil Mount bracket bolts #1539979
11/25/13 10:55 PM
11/25/13 10:55 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Are the coil bracket mounting bolts for a 426 Hemi OEM intake manifold dtfferent size than other Mopar coil mounting bolts?
Seller is claiming they're right. There's no way. They're too small. He's basically saying they're all the same for those years.
64-74 Mopar A B C E Body Coil Strap Bracket Bolts. These bolts are used to mount the Coil Strap Bracket to the intake manifold. Correct plating,free spinning washer and "23" head markings as originals.
Re: 71' Hemi Coil Mount bracket bolts [Re: Topcat] #1539980
11/26/13 12:07 AM
11/26/13 12:07 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
ALL but 6 bbl are 5/16-18 X.55 sems.phosphate finish. some SB apps known to be zink (yellow) dichromate. finish.
HEMI,S ARE FOREVER!!!
