e-body rear sway bar...what links to get for it? #1539622
11/25/13 01:50 PM
11/25/13 01:50 PM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
I hear certain year a-body front sway bar links will work w/this rear sway bar???
Re: e-body rear sway bar...what links to get for it? [Re: 2fast4yourBrain] #1539623
11/25/13 02:37 PM
11/25/13 02:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
A-body front links are the same as the E-body rear links. The ones in your picture will work just fine. It depends on if you want it to look stock or not.
Re: e-body rear sway bar...what links to get for it? [Re: burdar] #1539624
11/25/13 04:06 PM
11/25/13 04:06 PM
BDW Offline
BDW  Offline
Re: e-body rear sway bar...what links to get for it? [Re: BDW] #1539625
11/25/13 05:28 PM
11/25/13 05:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
E body rears use the same link kit as 1969 and older B or A body fronts
Re: e-body rear sway bar...what links to get for it? [Re: gtx6970] #1539626
11/25/13 09:21 PM
11/25/13 09:21 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Sweet, thanks!
Re: e-body rear sway bar...what links to get for it? [Re: 2fast4yourBrain] #1539627
11/25/13 11:18 PM
11/25/13 11:18 PM
IN
ahy Offline
ahy  Offline
IN
FWIW on my rear bar with that style link I had to "tune" the length of the links to clear both the the pumpkin and exhaust. The tie bolts were extra long and I used 1/8" thick small diameter shim washers to put the hoop on the bar where it needed to be. Works like a charm.
Re: e-body rear sway bar...what links to get for it? [Re: ahy] #1539628
11/26/13 04:05 AM
11/26/13 04:05 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
Does it matter if the washers are centered on the bushing?
Mine are sort of off center and look weird.
Any particular torque on them maybe they are too tight.
AAR cuda 71 rag challenger
Re: e-body rear sway bar...what links to get for it? [Re: 3406pac] #1539629
11/26/13 05:21 AM
11/26/13 05:21 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
If you want the absolute correct OE rear links, call Frank Battleson 804-285-2155.
