Got to dial the 318 back a bit #1538829
11/23/13 05:01 PM
11/23/13 05:01 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
It's -9 F. this morning and had to thaw the water hoses out for the dyno. Anyway, finally got a good seal on the cold side and the little napa rebuild made 535.8hp@4803rpm and 586ftlbs.@4803rpm. This was at 24lbs. of boost so I'll have to dial the boost back a bit and see if it will run on 87 octane. More to come.....Dave
Re: Got to dial the 318 back a bit [Re: quickd100] #1538830
11/23/13 05:38 PM
11/23/13 05:38 PM
Delray beach, Florida
P
Performance Only Offline
P
Pretty good power. What was the inlet air temp?
machine shop owner and engine builder
Re: Got to dial the 318 back a bit [Re: quickd100] #1538831
11/23/13 05:40 PM
11/23/13 05:40 PM
nielsville, minn.
Q
Q
nielsville, minn.
Still on 110 octane fuel at 12lbs. of boost it made [Email]356hp@4787[/Email] and [Email]434.7ftlbs@4002rpm.[/Email]
Switching to a little bit stiffer spring in the wastgate 18lbs. of boost it made [Email]460hp@4800[/Email] and [Email]518.1ftlbs@4350rpm.[/Email] Dave
Re: Got to dial the 318 back a bit [Re: Performance Only] #1538832
11/23/13 05:43 PM
11/23/13 05:43 PM
nielsville, minn.
Q
Q
nielsville, minn.
Dan, it's about 50 degrees in here but the dyno has a weather station that corrects the numbers to the standard.Dave
Re: Got to dial the 318 back a bit [Re: quickd100] #1538833
11/23/13 07:37 PM
11/23/13 07:37 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Absolutely awesome. How much timing did you have in it at 24psi?
Re: Got to dial the 318 back a bit [Re: dizuster] #1538834
11/23/13 07:57 PM
11/23/13 07:57 PM
nielsville, minn.
Q
Q
nielsville, minn.
Scott; All pulls were done at 20 degrees locked out. I just finished making 3 pulls on 87 octane@20 degrees also. On a cold motor it made 363.3hp@4779rpm and 437.9ftlbs@4016rpm. Water temp was 140F. At 160 it gave up 5hp. Motor is still in one piece and didn't rattle during the pulls. 12 lbs. of boost.
This winter it's going in my 81 Dodge 1/2 4x4. The truck could win 9 out of 10 ugly truck contests.Dave
Re: Got to dial the 318 back a bit [Re: quickd100] #1538835
11/23/13 11:39 PM
11/23/13 11:39 PM
pennsylvania
poboyengineering Offline
pennsylvania
"Got to dial the 318 back a bit"
words not often heard...good work!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Got to dial the 318 back a bit [Re: quickd100] #1538836
11/24/13 12:54 AM
11/24/13 12:54 AM
Dude, your flogging that puppy pretty hard , 22 lbs. of boost and still lives with 10 head bolts
Re: Got to dial the 318 back a bit [Re: Cab_Burge] #1538837
11/24/13 09:14 AM
11/24/13 09:14 AM
nielsville, minn.
Q
Q
nielsville, minn.
Cab; 24 lbs. of boost, with the other turbo it survived 28lbs. Right after it spit out 2 head gaskets in a row I got mad and bought an Isky groovamatic and o-ringed the block and installed copper head gaskets.
I've got a 78' 440 sitting right behind my dyno, the pistons are almost .200 down in the hole. I've got a spare steel crank, a set of Manley sportsmaster rods...think of the possibilities..... Mods, where is my mushroom cloud icon? Dave
Re: Got to dial the 318 back a bit [Re: quickd100] #1538838
11/24/13 10:01 AM
11/24/13 10:01 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
impressive results for sure,i never heard anyone that thougth there would ever be a need to step it back alitle with a 318..
oooh i seee where this is heading
you might not ever look the same at that 605hemi again if you start doing these things to that poor 440 aswell.
Re: Got to dial the 318 back a bit [Re: quickd100] #1538839
11/24/13 10:03 AM
11/24/13 10:03 AM
Andrews,In. U.S.of A.
67_Satellite Offline
110 octane and -9deg.air and 24 p.s.i.! Just everyday racing conditions in Heaven.
Re: Got to dial the 318 back a bit [Re: 1Fast340] #1538840
11/24/13 10:18 AM
11/24/13 10:18 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The big boost numbers scare people, but you have to remember that with the cam and heads as awful as these are, the cylinder isn't seeing what the intake is.
For example, "the otherdodge" has nearly the same size turbo as me, but with eddy heads and a better cam . It takes me 16psi to make the same power he's making at 13psi. (based on weight/MPH calcs).
I run 20psi compared to this 24psi, but at 200hp more. I guarantee mine has more cylinder pressure then his 318 to do that.
Boost is just a measure of restriction. 15psi on a stock iron head isn't the same about of air getting to the cylinder as 15psi on a w9 head.
Re: Got to dial the 318 back a bit [Re: 67_Satellite] #1538841
11/24/13 12:02 PM
11/24/13 12:02 PM
nielsville, minn.
Q
Q
nielsville, minn.
110 octane and -9deg.air and 24 p.s.i.! Just everyday racing conditions in Heaven. [/quote
The -9F. air outside, in the garage it was between 50 and 60F. My dyno has a weather station which corrects the numbers to the industry standards. Whatever the numbers are though, you see the difference the changes make. 24lbs-536hp, 18lbs-460hp, 12lbs-363hp, stock 318 with factory 2bbl carb and factory exhaust 166hp. All these numbers on the same dyno, all numbers corrected to the industry standard.Dave
Re: Got to dial the 318 back a bit [Re: quickd100] #1538842
11/24/13 12:57 PM
11/24/13 12:57 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I really need to get mine to a chassis dyno lol. I think I may be surprised
Re: Got to dial the 318 back a bit [Re: SLOW67] #1538843
11/24/13 02:37 PM
11/24/13 02:37 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Impressive, Dave.
Hey, Tim. How's the car coming?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Got to dial the 318 back a bit [Re: I_bleed_MOPAR] #1538844
11/24/13 08:08 PM
11/24/13 08:08 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Have I ever expressed my love for turbos?
Re: Got to dial the 318 back a bit [Re: I_bleed_MOPAR] #1538845
11/24/13 08:34 PM
11/24/13 08:34 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Impressive, Dave.
Tim
It's coming along, I've done alot more tuning on it but I've had my Duster/Dart to work on to so it's slow both ways lol. Is the trans working out good for you?
