MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? #1538805
11/23/13 04:42 PM
11/23/13 04:42 PM
NJ
rdrnr6970 Offline OP
Your #1 source for current events
NJ
working on my 70 dodge adventurer truck im thinking about the rust,and cost of restoring it.the roof u could probably open with ure bare hands its so rusty. i measured the dana 60 wheel to wheel and come up with 60 inches,im gonna measure again but could this be put into a say...roadrunner,dart,coronet anythoughts?i hear u usually have to cut the axels down?thanks guys.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538806
11/23/13 04:49 PM
11/23/13 04:49 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538807
11/23/13 05:02 PM
11/23/13 05:02 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Truck Dana's usually don't have pinion snubber provisions so it would have to go to a racecar build.
Ron
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: 340SHORTY] #1538808
11/23/13 05:23 PM
11/23/13 05:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They have to be cut and ends welded on.Pinion snubber isnt a big deal.Gus a member here has a Dana for me.I just have to see when my son can pick it up.My buddy will cut it and weld new ends on.Axles can be had for 300 or so new from Dr Diff.Rocky
Chrysler Firepower
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: RJS] #1538809
11/23/13 08:28 PM
11/23/13 08:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Ron
If you use the right springs and shocks you don't need a pinion snubber
Hey Rocky one of the hillbilly lube guys was sniffing around the Dana yesterday for his jeep I almost bought a chrome cover for it at summit today for $10.00 on the return table.
Gus
64 Plymouth Savoy
Dana 60
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: fourgearsavoy] #1538810
11/23/13 08:49 PM
11/23/13 08:49 PM
NJ
NJ
hey guys thanks for the info,any help would be greatand thanks to you gus!my dana has 6 leafsprings attached to it...john
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: fourgearsavoy] #1538811
11/23/13 10:27 PM
11/23/13 10:27 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ron
Gus
If you say so, funny when my car was running mid 10's I was always able to 60' like a 10 OH car with proper springs, shocks and Pinion Snubber.
Ron
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538812
11/23/13 11:18 PM
11/23/13 11:18 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Cal-Trac it.
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: RJS] #1538813
11/23/13 11:46 PM
11/23/13 11:46 PM
Rittman Ohio
Rittman Ohio
Ron
Gus
Ron
Just think how much better it would work if it wasn't bound up with that pinion snubber wedged against the floor pan
All kind of setups out there that work for different cars but most chassis guys will tell you the snubber is just a bandaid.
Gus
64 Plymouth Savoy
Dana 60
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538814
11/24/13 12:41 AM
11/24/13 12:41 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Isn't the tube diameter 3.5 inches instead of 3"?
I thought you had to use a 3/4 ton ford Dana. I could be wrong though.
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: drew72] #1538815
11/24/13 01:14 AM
11/24/13 01:14 AM
Dana made the Dana 60 housings with many different diameter axle tubes, from 2.5 inches to 3 1/4 inches, I believe The ones made for the Mopar pasenger cars had 3.0 inch diameter tubes with the pinion snubber pad machined in and drilled and tapped for the retaining bolts, big no good bandaid as far as traction is concerned I have not seen one myself but I have heard that Dana made some 60 models rear ends for Ford 1/2 ton pickups with 5 bolt flanged non full floating axles that had the 3.0 diameter axles tubes also The one bad thing about the 3 1/8 and 3 1/4 axles tubes in a street passenger car with stock leaf springs is getting or making a lower shock mount plate and finding a set of U bolts for the bigger axle tubes On a race car it is no big deal to open up the weld on axle brackets to fit the larger tubes for ladder bars or 4 link brackets As already said when using a 3/4 ton Dana 60 housing you do need to cut and replace the axle ends so you can use a set of stock Mopar rear brakes and stock type passenger car axles with 5 lugs also Unless you really want to run 8 lug wheels and full floating axles I've seen that done also
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: fourgearsavoy] #1538816
11/24/13 08:58 AM
11/24/13 08:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Gus I havent been to Summit forever.Since I retired the $$$ is tight.That and the wife has me working more than when I was wrenching.I have to see when my kid can drive me down.He works mostly from 10 or so to 6.30.Makes it a pain.Rocky
Chrysler Firepower
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: therocks] #1538817
11/24/13 11:18 AM
11/24/13 11:18 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
When I had a truck Dana that I was considering using, I was thinking of fabbing a snubber to bolt to the floorpan.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: I_bleed_MOPAR] #1538818
11/24/13 02:00 PM
11/24/13 02:00 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I have one for my wagon from an early 70's Dodge truck assy. 3 in tubes but 1/2 in thick tubes.Tubes welded in. It is a 60 HD.(cast HD inside) Extra 30# or so but ok for a street car.No fun cutting those tubes.Also fabbing a snubber for the floor.
Leave the gun.......take the Cannoli's....Mike
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: mike s] #1538819
11/24/13 02:10 PM
11/24/13 02:10 PM
NJ
NJ
thanks again guys!
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538820
11/25/13 12:33 PM
11/25/13 12:33 PM
dogdays Offline
dogdays  Offline
In case you hadn't picked it up, no one is saying bolt the Dana 60 in without first converting it from 8 lug, full floating hubs to a passengercar style semi floating rear with passengercar style brakes and 5 on 4.5 bolt pattern for the wheels.
R.
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: dogdays] #1538821
11/25/13 02:41 PM
11/25/13 02:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
R.
I did that to mine. Mine is out of a 68 dodge 3/4 ton truck. It's under my race car now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: 6PKRTSE] #1538822
11/25/13 07:41 PM
11/25/13 07:41 PM
NJ
NJ
cool guys got it,and thanks for the pics!
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: rdrnr6970] #1538823
11/25/13 10:57 PM
11/25/13 10:57 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
If you can find an early 60s Imperial , they had Danas but the bolt pattern is the same as the older Ford P/us . Its 5 hole but maybe 6" bolt pattern
Re: MIGHT PUT A DANA 60 FROM 70 DODGE TRUCK IN CAR? [Re: mopar_man] #1538824
11/26/13 12:40 AM
11/26/13 12:40 AM
Me thanks that was not so on the Dana 60s in Imperial, I had a number of those cars,pre 1966, and all of them had 8 3/4 in them
