Re: 99 Ram Heater problem- not hot enough.
[Re: pjc360]
#1538526
11/22/13 11:12 PM
11/22/13 11:12 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
My 96 Ram 2500 with a V-10 takes forever to warm up. You would think with all of the cylinders moving it would build up heat quickly. I think the rad & coolant system is so large & effecient it never wants to warm up. It has never had the greatest heat. I have changed water pumps, t-shats to the higher 195, spent the $80.00 on the OEM t-stat also as recomended by everyone on here, etc. Nothing works. Every year or two I flush the heater core & it gets much, much better with heat in the cabin but still takes forever to warm up. Been this way since 96.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dartslantsix]
#1538527
11/22/13 11:42 PM
11/22/13 11:42 PM
RapidRobert
first I'd shoot the stat housing/rad with the IR gun & see if it's getting hot enough then I'd see if there's enough flow thru the heater core & if (1) & (2) are good then see what vac door/servo is inop/cable misadjusted
[Re: Dartslantsix]
#1538529
11/23/13 11:14 AM
11/23/13 11:14 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Does the motor get to0 a good temp?Before you change a stat thats the first thing.Then if its right feel the heater hoses.They should be close in temp.If ones is colder than the other iots the core.Try flushing and reverse flushing it.My 99 Durango had just warm heat.I flushed it and the heat was better.It probally needs a core but Its a pain to change.Last one I did at the shop was about 4 to 5 hours.I run the 195 stat in it.Rocky
Chrysler Firepower
[Re: therocks]
#1538530
11/23/13 11:49 AM
11/23/13 11:49 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
The heater cores are problematic on these, I did a pile of them while at the dealership and I'm doing my '98 Ram tomorrow (along with the evaporator)
The cores are aluminum and are known to be a problem, a 8-9 hour job I'm not looking forward too. Heat has been slack the last few years and now the dreaded steam is rolling out the vents...
If the temp gauge is reading normal and the t-stat is ok it could be the blend air control but they rarely fail, can't hurt to check that the door is in the full heat position.
"I think its got a hemi"
[Re: Dartslantsix]
#1538533
12/01/13 09:44 PM
12/01/13 09:44 PM
RapidRobert
Success! That's good to hear especially with cool(er) weather coming on. Actually heater cores do not flow as much coolant as you'd think as it is only a mini parallel bypass & most of the psi/flow is the main cooling system so you do need em to be unobstructed
