Re: A518 Wiring Question
[Re: pimp2303]
#1538271
11/22/13 03:50 PM
11/22/13 03:50 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
do you have the 3 wire.or 2 wire plug?
[Re: pimp2303]
#1538273
11/22/13 07:17 PM
11/22/13 07:17 PM
Posts: 587 AL
jglen490
AL
Looked for a wiring diagram, but the best explanation I've seen so far is HERE Might be helpful.
[Re: stumpy]
#1538277
11/23/13 01:49 AM
11/23/13 01:49 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The wireing is simple but how you want to control the solenoids can be more complicated. On the three wire plug the center plug is 12 volts and it feeds both the overdrive and lock-up solenoids and the two outer wires are the ground circuits for the overdrive and lock-up solenoids. Basically you just put key on 12 volts to the center wire and then decide how you want to control the two solenoids by grounding the two outer wires which are the Overdrive solenoid and the Lock-up solenoid. When the outer wires are grounding it actuates overdrive or lock-up depending on which one is grounded. I forgot which outer wire is which solenoid. You just have to decide how you want to control the ground on the outer wires to get overdrive gear and the torque converter lock-up. Ron
[Re: 383man]
#1538278
11/23/13 08:30 AM
11/23/13 08:30 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
attached a diagram for what I did with mine.
"I think its got a hemi"
