Re: 67 Coronet exhaust manifold removal
[Re: floridian]
#1538103
11/22/13 01:32 PM
11/22/13 01:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't mean to be a jerk, but why would you need an exhaust manifold gasket? They didn't come that way. I don't use em. Ever. I would guess that motor is fresh from your post. I know those manifolds warp a little over the years. Did you make sure the mating surfaces on both the head and manifold are flat before assembly? Just saying if you blew a gasket already it might become an on going problem.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1538105
11/22/13 02:17 PM
11/22/13 02:17 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Exhaust manifolds were machined flat, and yes I used a gasket when I assembled it.. After it blew I took off the manifold and slid the gasket out, retightening the manifold and now it is worse than it was... All my tools are here in Florida now so taking out the steering column is probably undoable...
So nobody here has taken off one while in the car??
[Re: floridian]
#1538108
11/22/13 04:45 PM
11/22/13 04:45 PM
Posts: 1,584 MD
p d'ro
MD
I can get the bolts/nuts off, I just cant get the back of the manifold out by the steering column.. Yes it has PS....
ok, sorry. I never tried it. I will ask a friend with an RT coupe.
[Re: p d'ro]
#1538109
11/22/13 04:52 PM
11/22/13 04:52 PM
Posts: 5,169 CT
GTX MATT
CT
If you want to pull the column you need a half inch socket/ratchet for the lower 4 bolts on the firewall, a deep 7/16 for the two that hold the column to the dash, a medium sized philips head or similar to knock the roll pin out of the coupler, and a hammer to hit the screwdriver with.
[Re: GTX MATT]
#1538110
11/22/13 04:58 PM
11/22/13 04:58 PM
Posts: 2,637 Nashville, TN
MOPARMIKE69
Nashville, TN
Just loosen the manifold, cut a notch out on the bottom of the gasket bolt holes. Slide it in and tighten. Done! Especially since you are limited in time.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1538111
11/22/13 05:44 PM
11/22/13 05:44 PM
floridian
Lakeland FL
You must not have read my previous response.. Already tried this and it got worse.. Unstartable even... A chunk of gasket must be on it still and I cannot get the manifold far enough out to see or scrape it.
[Re: GTX MATT]
#1538112
11/22/13 05:47 PM
11/22/13 05:47 PM
floridian
Lakeland FL
Wonder if I did the firewall bolts and the two column if it would go down far enough to give it enough room without taking it off the steering box??
[Re: p d'ro]
#1538113
11/22/13 05:51 PM
11/22/13 05:51 PM
floridian
Lakeland FL
Do u have power steering? The only way I could get on the rearmost manifold bolt was with a European wrench that is bent at neck, while laying on back under car, and turn about 1/16 turn at a time. I was just tightening and not removing. Good luck and sorry. Nice car! My red brother..
Harbor frt makes a long skinny ratchet, 1/4" one end 3/8" the other) both ends flex.. With a shorty socket you can do wonders with it..
[Re: RBSat66]
#1538115
11/24/13 01:10 PM
11/24/13 01:10 PM
floridian
Lakeland FL
Use a Remflex gasket set and you"ll not have this problem again. I think I took my manifold off by double nutting the stud and removing it. It's been a while so I could bee mistaken.
So your saying removing all the studs will enable me to remove the exhaust manifold? Already have the Remflex gaskets purchased.. If I could just get the darn thing temporarily going without the HUGE leak it has ( since removing the bad gasket and just reinstalling the manifold) to get it moved I would be happy....
[Re: Polarapete]
#1538120
11/25/13 02:03 PM
11/25/13 02:03 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
This is beginning to sound a lot like one of my projects...the $600.00 washer Like I am going to replace the washer on the bathroom faucet and $600.00 later, I have a new bathroom sink and fresh paint on the walls to match
![](/ubbthreads/images/graemlins/iagree.gif)
This is a big block , ALL the exhaust studs are WET , if you plan on pulling the all the studs ... silly to even consider it ... you better start by draining the cooling system because things are going to get MESSY.
Nevermind if they are in there and you have no leaks around them I can just see the next topic after you button things up ... why is there coolant leaking from my exhaust manifold ???
Unbolt the motor mounts and jack up the motor on one side or pull the steering column ...
