need advice on Spare Tire size #153807
11/20/08 03:00 AM
11/20/08 03:00 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Im asking about my 65 Fury Station Wagon. Currently on the rear of the car I have 275/60/15 tires and on the fronts I have 215/70/15 tires.
What would a good all around size be for a spare? I am just planning ahead,because you never know where the flat is going to be. I dont know if it matters but the vehicle has an open 8-3/4 rearend.
Re: need advice on Spare Tire size [Re: SPWC] #153808
11/20/08 11:03 AM
11/20/08 11:03 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If you have a suregrip rear then you need the spare to be close to the same diameter as the rear tires.
Looks like a 235-70X15 would work. See tire height chart clickhere
