15x6.5" Trim Rings Info #1538034
11/21/13 10:53 PM
11/21/13 10:53 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
Sorry, I think I might be beating a dead horse on this one but here goes...
I have a very nice set of 15x6.5 rally wheels and with factory type trim rings apparently made out of unobtainium I have been scouring the archives here as well as the net in general trying to work out if there something which comes close to that factory look. I've found some older posts which point to Ebay auctions which are long since closed, and some which say Chevy 15x8 rally trim rings will fit, but I'm seeing many variations of those out there. Anyone have some advice?
71 Charger R/T 67 Barracuda 99 Ram Sport 09 Challenger R/T
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538035
11/21/13 10:56 PM
11/21/13 10:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What years are you talking about?
Re: 15x6.5" Trim Rings Info [Re: 71birdJ68] #1538036
11/21/13 11:49 PM
11/21/13 11:49 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
My understanding is that they 15x6.5 was only available for a few years in the mid 70s. I would prefer brushed finish rings but if all I can get are polished I can live with that.
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538037
11/21/13 11:56 PM
11/21/13 11:56 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Probably not what you are looking for but...
These are from a 70's full size Pontiac.
They are brushed aluminum.
Wish I had a better shot of 'em.
I have mechanical Aptitude.
I can screw up anything.
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538038
11/22/13 07:55 AM
11/22/13 07:55 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I just purchased some generic trim rings from Summit, I have 15 x 6.5 on the front of my GTX.
http://www.summitracing.com/parts/sum-55-2533v/overview/
They fit pretty good.
Re: 15x6.5" Trim Rings Info [Re: gdonovan] #1538039
11/22/13 09:55 PM
11/22/13 09:55 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
Those don't seem too bad at all. I was trying to look at them on Summit this past week but the picture of the front doesn't work on there. Even looks to have a nice crisp break near the outside of the rim.
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538040
11/22/13 11:40 PM
11/22/13 11:40 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I can take some better shots if you like.
"I think its got a hemi"
Re: 15x6.5" Trim Rings Info [Re: gdonovan] #1538041
11/23/13 01:43 AM
11/23/13 01:43 AM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
Sure, that would be great
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538042
11/23/13 09:34 AM
11/23/13 09:34 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Here is a better shot.
Re: 15x6.5" Trim Rings Info [Re: gdonovan] #1538043
11/23/13 09:53 AM
11/23/13 09:53 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
One I took this morning, for the money they are tough to beat.
Re: 15x6.5" Trim Rings Info [Re: gdonovan] #1538044
11/23/13 12:11 PM
11/23/13 12:11 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Those are nice, would you measure the depth for us to see if they would fit/look OK on a 15X7 cop wheel?
Want to avoid too much gap on the inside if possible
because they're orange wheels.
Thanks, Joe
Re: 15x6.5" Trim Rings Info [Re: jlatessa] #1538045
11/23/13 01:15 PM
11/23/13 01:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks, Joe
From Summit's site;
Notes: 2.50 in. width ring. Under lip to inside edge is 2.00 in. depth.
Those do look nice for the $$
I may have to buy one and see if I can give it the brushed finish
Re: 15x6.5" Trim Rings Info [Re: roadhazard] #1538046
11/23/13 05:19 PM
11/23/13 05:19 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
If you do that let us know how it works out, I'm gonna go ahead an get a set and I'd like to see how well they brush out.
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538047
11/24/13 01:47 PM
11/24/13 01:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Here is a pic of the Wheel Vintiques 15 x 7 brushed ring. They appear to be too deep. I measure about 3 inches deep from lip to edge. Will sell them for $125 set of 4.
Re: 15x6.5" Trim Rings Info [Re: mopars4ever] #1538048
11/24/13 02:32 PM
11/24/13 02:32 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
Those look a lot like the rings I removed from the wheels. Here's some pics of my best old ring.
Edit: Fixed the attachement, Not a fan of the 4 spring clips retaining system on this one
Re: 15x6.5" Trim Rings Info [Re: BCSharp] #1538049
11/26/13 03:49 PM
11/26/13 03:49 PM
Kent, WA
triple_green Offline
Kent, WA
Are you looking for perfect ones?
I think I have some used ones around that are marked 15x6.5.
What exactly should they look like? Brushed finish?
Mark
68 Charger, 383 HP console auto, spring green, stock restoration
Re: 15x6.5" Trim Rings Info [Re: triple_green] #1538050
11/26/13 08:56 PM
11/26/13 08:56 PM
Central New York
bfury Offline
bfury  Offline
Central New York
I beat this horse a couple of years ago. I had 4 of those rims and sandblasted, epoxy primed and painted to use. I couldn't find the right rings that would fit and stay. I finally found some NOS for $1000 and another set for $400. I replaced all the wheels with 15 x 7 and 15 x 8 repros and rings from Summit for the same money and sold the finished rims for a few hundred. Some of that size were used on the TA's and AAR's. Others were from the mid 70's. The mid 70's ones are not worth a lot. Hope they work out for you though.
No Stock
Re: 15x6.5" Trim Rings Info [Re: bfury] #1538051
11/27/13 07:29 AM
11/27/13 07:29 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I must have got lucky, no problems at all so far and I push the car pretty hard when I'm in the mood.
