Re: Rebuilt front end clunk
[Re: joes68340s]
#1538029
11/23/13 09:24 PM
11/23/13 09:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
With the Poly lower bushings, I would suspect that the arms may be shifting fore/aft under load on the bushings, measure a fixed point between the lower control arm bushing bore, then repeat the action that causes the "clunk", and remeasure the set distance to see if the arm has moved, if so, you'll need to draw the lower control arm forward, via the brake reaction strut/rod...you'll need to unload the suspension to do this, if this is the cause...
