4 speed help
#153767
11/20/08 12:49 AM
11/20/08 12:49 AM
I have a 4 speed in a 70 Coronet that I can't get to go into reverse. I rebuilt the trans with new bearings and senc. It shifts throught the 4 gears great but won't go into reverse for anything. Please help
Re: 4 speed help
[Re: 6bblFLASH]
#153770
11/20/08 01:02 AM
11/20/08 01:02 AM
I can't get the lever to move when I put a wrench on it from under the car. I have tried turning the drive shaft while trying to shift it into reverse. And I can't get it to shift
Re: 4 speed help
[Re: Stanton]
#153775
11/20/08 05:41 PM
11/20/08 05:41 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
The side cover has nothing to do with reverse, the reverse actuator is in the main case.
As suggested a few posts above, I think the reverse lockout lever may need adjusting. The lever is held in place by the side cover, so you'll need to remove the side cover to see how it works in relation to the two other levers on the backside (inside) of the cover.
Make sure everything is in neutral before you install the side cover.
Re: 4 speed help
[Re: John_Kunkel]
#153776
11/20/08 05:55 PM
11/20/08 05:55 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Sorry, but the side cover has EVERYTHING to do with the Reverse lockout; the cam on the internal Reverse lever makes contact with the internal 1-2 shift lever to prevent engagement of reverse, if the side cover is too low the cam will contact the 1-2 shift lever even if the lever is in Neutral.
I talked to both Passon and Brewers about a similar problem at the Nats and they both said the same thing, check the shifter and if not that then the side cover needs adjustng.
