Re: Street / Strip(Overdrive) automatic trans choices ..
[Re: bigdad]
#1537590
11/21/13 02:41 AM
11/21/13 02:41 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
We did a A500 for awhile, with no lock up and a 904 input. With a swich on the shifter for overdrive. It's smaller/ lighter than a A518.(still heavy and long). What kind of power from the small block? What kind of strip time, bracket racing or fun/grudge/et chase? I like the car
"Just a Bracket car dressed up like a streetcar"
[Re: bigdad]
#1537591
11/21/13 03:07 AM
11/21/13 03:07 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
SMR Transmissions has od options for street and race applications. Pat is a great guy to deal with, but they are in Canada.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: ksj]
#1537594
11/21/13 10:52 AM
11/21/13 10:52 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
What rear gear ratio are you going to run?
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#1537595
11/21/13 12:35 PM
11/21/13 12:35 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The plan is to get it up and running with a basic small block ..Like maybe 400 hp or so ?
Get some of the bugs worked out of it then, put a real power plant in it .
So, ET expectations in the beginning would be low 11's and it will be driven to some local tracks the furthest one I'd drive to would be 250 miles ..
I suppose the rear geat will be like 4.30 ?
Putting a Dana under it
Up for suggestions on power / drive train..
I hate to put this out there but, I'd like to try drag week ..It may never happen but, its a goal
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#1537600
11/21/13 07:54 PM
11/21/13 07:54 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd look at a GM 200R4.Plenty strong for a stock eliminator car and small case as well.
[Re: Chris2581]
#1537601
11/21/13 10:08 PM
11/21/13 10:08 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
what ever trans you want and a gear vendors over drive.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: cudadoug]
#1537605
11/22/13 02:44 AM
11/22/13 02:44 AM
Just-a-dart
Glendora Ca.
IIRC, you went mid 10's with that A500, didn't you? I have a few questions if you don't mind:
1) What valve body did you use?
2) Why no A500 now?
3) What kind of cutting/fab/mount did it take to get it the car?
Thanks!
Low 11.s with that set up. 1) Protrans set it up with one of his own forward man. V.b. 2) Heavy and long, and a bit of a power eater compaired to a 904. Also to get enough converter to really make the car happy with the current engine combo it will have alot of slip in O.D. 3)Reshape part of the tunnel some. Cut out the top of the trans cross member and make a newer lower with a Chevy trans mount. Then I made a new cross member/drive shaft loop to replace the strength of what was cut out.
This set up will probably go back in the car with a 6.4 hemi in the future with my son playing with it. But my new junk has to run 1st.
[Re: Chris2581]
#1537608
11/22/13 11:23 AM
11/22/13 11:23 AM
Posts: 596 Mass.
80fbody
Mass.
There was an A-Body build with the 200R4 trans over on FABO awhile back. That trans really looked like it could be the best small case overdrive unit as there are enough parts to make it hold up. Would like to build one myself sometime.
