Drilled rims for slicks question. #1536939
11/19/13 02:11 PM
11/19/13 02:11 PM
1969proDart Offline OP
Ok, question is if a room is drilled for slicks does it affect a regular tires grip as far as dismounting from the rim while driving
Re: Drilled rims for slicks question. [Re: 1969proDart] #1536940
11/19/13 02:33 PM
11/19/13 02:33 PM
No since you have 360 deg of sealing surface & the only way I could see there being a problem with the holes that are left is if the dia of the holes is so great that the bead might shift in daily driving & let air out but I am assuming when you drill holes for slicks that the holes are small so I dont THINK there will be a problem but I am speculating since I have never ran drilled rims so here's a BTT for ya
Re: Drilled rims for slicks question. [Re: RapidRobert] #1536941
11/19/13 02:47 PM
11/19/13 02:47 PM
ok cool thanks!
Re: Drilled rims for slicks question. [Re: 1969proDart] #1536942
11/19/13 10:18 PM
11/19/13 10:18 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you're the nervous type you can use some bead glue when you put the new tires on.
