What to get for igniton system?
#153618
11/19/08 10:09 PM
11/19/08 10:09 PM
Posts: 169 Maine
itali83
Maine
Hey everyone, I'm looking to buy an ignition system for my car. I'm doing a complete restification and have already built the motor but don't have anything to work with for acessories so I need to buy everything. I definitly want electronic ignition, the motor is a mild 440, .040" over, mild hydraulic cam, aluminum heads, dual plane intake, nothing crazy. It will be a street strip car with plenty of strip time. I was wondering if I should buy the conversion kit for my current distributor or buy a completely new one. Also, should I get a MSD box , and if so, which one is the best for what I need. I'd like to have a rev limiter but being an auto car, I don't know how much that'll be needed really. I need to start looking at pricing as I now have more of a budget to follow and no more "money is no object" scenario. Let me know what combo's work for you. Thanks in advance! ![](/ubbthreads/images/graemlins/thumbs.gif)
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: What to get for igniton system?
[Re: itali83]
#153619
11/19/08 11:27 PM
11/19/08 11:27 PM
RapidRobert
I would consider FBO coil/ecu.
[Re: RapidRobert]
#153620
11/21/08 12:40 PM
11/21/08 12:40 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
to me... Mopar performance ignition is good enough and still a Mopar
[Re: NachoRT74]
#153622
11/21/08 01:24 PM
11/21/08 01:24 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
I got the MSD 6al thats black with a MP logo on it. You can run them off a stock elec distributor or points distributor, and it totally deletes that pesky ballast resistor.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: itali83]
#153625
11/22/08 09:40 AM
11/22/08 09:40 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I like MSD 6AL for a few reasons,works great with Mopar distributor,rev limiter,and reliable.Oh and one more,if it ever does fail just send it back to MSD and it will be better than new for around $30.00. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Lefty]
#153626
11/22/08 01:28 PM
11/22/08 01:28 PM
Posts: 211 ILL
Greentween
ILL
I have a Pertronix distributor on the 440 in my Coronet and it works great. I checked the advance curve and it was already set up for a 440 per Ebergs article in Mopar Action. You don't need the MSD with this dist, it has the proven Pertronix module in it. I also have the 60,000 volt Pertronix "Flame Thrower" coil. The engine starts quickly with the setup. It is a vacuum advance dist. My fuel economy went up dramatically after hooking up the vacuum canister. Highly recommended for a street motor imo...
I dont recommend the Pertronix. I had bad results with it. I did back to back to back tests comparing the pertronix dizzy with my FBO dizzy and FBO box. With the pertronix the car would not idle correctly. Same timing both dizzys, no answer from pertronix as to why, although they did recommend different things to try (coil, direct 12v power feed, ect). Pop the FBO one back in and use its box, and car would idle perfect.
Plus the Pertronix you will need to grind on the head for it to fit (stock head).
[Re: RapidRobert]
#153630
11/22/08 07:11 PM
11/22/08 07:11 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I would pony up for a MSD. ![](/ubbthreads/images/graemlins/Twocents.gif) The 6AL should be fine,,,,i have that in the Charger (street car),,,,and have a Digital 6Plus in the Belvedere (race car) I have run the MP orange,,and chrome,,,,and also did the FBO system... ![](/ubbthreads/images/graemlins/smoke.gif) I like the MSD by far... ![](/ubbthreads/images/graemlins/beer.gif) Much easier on starting,,,built in rev limiter,,,car ran ALOT better.......... I "hid" mine under the dash/glove box,,,and ran the wires thru the firewall....very clean looking....... ![](/ubbthreads/images/graemlins/stirthepot.gif) I had nothing but problems with the FBO stuff,,,kept burning ballast resisters,,,and then a ECU box.... ![](/ubbthreads/images/graemlins/no.gif)
[Re: 69CHARGERMD]
#153633
11/22/08 09:42 PM
11/22/08 09:42 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Same here. Went thru 2 ballasts, then the FBO ECU failed, replaced with a MP chrome ECU, 1 more ballast then the MP ECU failed. All this within 1000 miles. I think it was the FBO coil causing the failures Went back to a MP chrome, cheap Accel SS coil, 1.25 ohm ballast, 15,000 miles without a let down.
The MP chrome box is more than enough for most street cars (stay away from the MP orange box). If you want more, I'd go with a Mallory Hy-Fire 6al before the MSD 6al. You'll get more features for less $.
[Re: RapidRobert]
#153635
11/22/08 10:47 PM
11/22/08 10:47 PM
Posts: 169 Maine
itali83
Maine
Thanks everyone for your input. What is this FBO set up some are talking about. I'm really looking at keeping it simple and getting the mopar performance electronic conversion kit. Distributor, wire harness, box, ballast all in one. I can always add an ignition box at a later time if needed but I really want to get this car together before gas is illegal or 50 bucks a gallon so I need to simplify things where I can. Thanks again.
