318 wont start after alternator problem....... #153556
11/19/08 08:47 PM
11/19/08 08:47 PM
alberta
Publicbottle Offline OP
alberta
HI guys, working on our 318 because the lights/accessories all of a sudden died....tested the alternator and it failed, replaced the brushes and put the alternator back in and now it wont start!! How is the ignition system and the charging system related?? I never disconnected the battery before removing the alternator but i am sure nothing arced during the proccess....any tips?
Re: 318 wont start after alternator problem....... [Re: Publicbottle] #153557
11/19/08 09:26 PM
11/19/08 09:26 PM
what means dont start? turn over or run? i believe the igition wire that feeds the VR goes straight to the alt field. short that out and it might not start....
Re: 318 wont start after alternator problem....... #153558
11/19/08 09:28 PM
11/19/08 09:28 PM
alberta
alberta
hmmmm...
ya it turns over but no ignition
Re: 318 wont start after alternator problem....... [Re: Publicbottle] #153559
11/19/08 09:29 PM
11/19/08 09:29 PM
need to find what went open that killed the lights etc. I'd see if you have fire at the fusible link then the bulkhead then the ammeter terminals for a start. EDIT I missed the 1st 2 posts while I was posting. Disregard my post.
Re: 318 wont start after alternator problem....... [Re: RapidRobert] #153560
11/19/08 09:51 PM
11/19/08 09:51 PM
look at this schematic.
http://www.mymopar.com/downloads/1970/70ChallengerA.JPG
disconnect the blue field wire from the alt and try it. but if that was shorted, youd probably melt something
Re: 318 wont start after alternator problem....... #153561
11/19/08 11:21 PM
11/19/08 11:21 PM
with a test light or VOM see if you have fire at the coil positive terminal when the key is "on" and when it is in "start". If not trace it back to the ign sw & see where the "open" is. Also check that the ECU has fire when "on" and "start"
Re: 318 wont start after alternator problem....... [Re: RapidRobert] #153562
11/20/08 04:38 AM
11/20/08 04:38 AM
alberta
alberta
ya i have approx 6volts on the + coil terminal...which sounds right to me....agree?
