OBD I Code Check? #153524
11/19/08 08:25 PM
11/19/08 08:25 PM
Imlay City, MI
DTT Offline OP
super gas
DTT  Offline OP
super gas
Imlay City, MI
The Check engine light came on in my 94 Grand Cherokee today. I turned the key on and off 3 times and watched the MIL blink...which from memory is the correct way to check for codes on this era vehicle...
I had a few different "codes" come up. Any idea on what they are? Is there a sheet which explains what each number of blinks is?? Thanks
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
Re: OBD I Code Check? [Re: DTT] #153525
11/19/08 08:34 PM
11/19/08 08:34 PM
Rancho Cordova, Calif.
davidcwhitney Offline
Try to put your hands on a Haynes manual. Mine has most of the dashboard codes listed, though the answer you get does not always tell you what the fix is.
Also try
http://www.allpar.com/fix/80s-codes.html
Happy motoring,
David
1977 Executive Diplomat II
