Engine pressures and PCV issues, LA engine (HELP.)
#1534996
11/18/13 09:40 PM
11/18/13 09:40 PM
Posts: 4,185 here.
Remy-Z
here.
The 323ci (worked 318) in my Imperial is eating oil with no proof. No smoke, no sludge, no leak. I'm about 85% sure I've traced it to the PCV-to-carb line, but I'm not 100% sure about how to go about this...
What happens: Around town driving (under 60mph), the car is fine with no oil loss. At highway speeds (65-ish-80mph) I'm losing oil at the rate of about 1qt/hr, speed dependent. There is no residue that is worth noting anywhere near the exhaust.
Ideas: This engine has always had high pressure. It's blown off two breathers. The PCV valve hose is "sweating" oil, how I don't know.
Need to know: is the PCV gone, or do I need to build a baffle system to keep the oil from migrating into the carb?
Any other info needed, please ask and I'll help out. This car is getting driven cross-country in about a month and I want this engine to live.
Re: Engine pressures and PCV issues, LA engine (HELP.)
[Re: Remy-Z]
#1534997
11/18/13 09:54 PM
11/18/13 09:54 PM
RapidRobert
Yes you need baffles on the valve cover that houses the PCV. Likely that will take care of you, & if not blowby may be excessive especially if the PCV on one side ain't clogged & neither is the breather on the other side & you did mention there is excessive crankcase pressure which is blowby.
[Re: Remy-Z]
#1535001
11/19/13 01:12 PM
11/19/13 01:12 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
the above statement indicates excessive crankcase pressure, ASSUMING the breather on the other valve cover is open to atmosphere.
The valve covers should be baffled to prevent oil loss but that will not cause the breathers to blow off. You could try running it without the pcv using two open breathers but you may find a mess in the engine compartment IE: oil everywhere. Sounds like rings ![](/ubbthreads/images/graemlins/pity.gif)
