Re: 7qt deep oil pan
[Re: sbmopar]
#1534645
11/18/13 02:33 AM
11/18/13 02:33 AM
RapidRobert
Are you & him bench racing or are you having specific issues with your 273?. Is this a daily driver? No factory tc tensioner but MP has one. A hi vol pump costs power & excessively wears the inter gear (not a dealbreaker in itself) but is only used/needed if a std pump with a hi psi spring cannot maintain pressure because of either racing clearances and or a high mileage worn eng with excessive clearances. More info please.
[Re: Commando1]
#1534649
11/18/13 01:30 PM
11/18/13 01:30 PM
RapidRobert
Go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Charles Sanborns' oiling mods that are in a sticky at the top of the page. This will give you an opportunity to gain some knowledge from the real "Mopar Charlie"
[Re: Commando1]
#1534650
11/18/13 01:35 PM
11/18/13 01:35 PM
Posts: 30,481 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Mopar Charlie is very traditional Old Skool. After 30-40+ years he's opinionated on what he knows works and doesn't work. Unless you know for a fact that you are smarter than him, the unwashed has a better chance to heed his advice than to not.
VERY opinionated and uNwashed ? ...,, now THIS reminds me of someone located just south of Avon Park !!
[Re: sbmopar]
#1534651
11/18/13 02:01 PM
11/18/13 02:01 PM
Challenger 1
Cincinnati, Ohio
This guy called Mopar Charlie in fla is telling me that on my 68 ply val w/ 273 I can't put a deep oil pan it won't fit the chassis and never use a high volume oil pump , also said that no timing chain tensioner was ever used on small blocks . Anyone agree with this ? Who makes a pan that will fit ? What's your thought on the high volume oil pump. Too
with old charlie.
I had to notch my K to clear my 7 quart pan on my 340 E body.
Haven't used a Hi volume pump either since like the early 80s. My current 340 that I built in 2007 got a used standard pump from my previous motor.
I have run this motor out at bonneville and area now at over 100 mph 4500-5000 RPM for like 4-5 miles at a time. Never hurt the motor with a standard oil pump on it. Doesn't sound like much?, try it sometime.
And the next time I take it out of the car, it is getting the standard pan put back on, because it does hang pretty low and I have beat it out at least twice now.
I am talking about a street engine at maybe 6500 rpm.
I'm not young enough to have hot rodded the magnum engines, so can't comment about timing chain tension-er. I have never used one in SB mopar.
Stock style pan waiting to go on, I cut up all my stock pan years ago to make hi volume pans out of them before I could afford the 7 qt milodon pan I have on it now.
