help me id this battery cable #153449
11/19/08 05:54 PM
11/19/08 05:54 PM
md
mopars4ever Offline OP
md
Can anyone tell me what this NOS positive battery cable fits? The part number is 3764903. It doesn`t show any application on lightningjar.com. It is about 42-43 inches long. thanks
Re: help me id this battery cable [Re: mopars4ever] #153450
11/19/08 10:29 PM
11/19/08 10:29 PM
md
md
bump
Re: help me id this battery cable [Re: mopars4ever] #153451
11/20/08 09:00 AM
11/20/08 09:00 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what cars have the starter relay next to the battery ?? the numbers tells me it's mid 70's , A body or an F body ?
Re: help me id this battery cable [Re: mopars4ever] #153452
11/20/08 09:14 AM
11/20/08 09:14 AM
New Jersey Bada Bing
bremotorsports Offline
Keep in mind that battery cable tag numbers are often engineering numbers, not service part numbers.
Bill Rolik
Re: help me id this battery cable [Re: bremotorsports] #153453
11/20/08 12:16 PM
11/20/08 12:16 PM
md
md
Bill, I have the original box and it has the same part number. John, It isn`t F body because I compared it to my 77 volare and it is very different. The guy I bought it from said he found it in the trunk of a 76 dart but the A body cables I have seen are different. Mike
Re: help me id this battery cable [Re: mopars4ever] #153454
11/20/08 12:37 PM
11/20/08 12:37 PM
JohnRR Offline
JohnRR  Offline
Only other thing I can think of is 75ish B body ? or 73 74 b body but those I assume would be the same as e body , the part number to be is post 75 , what's different from the a body cable ?
Re: help me id this battery cable [Re: JohnRR] #153455
11/20/08 01:49 PM
11/20/08 01:49 PM
md
md
I found it a 74 parts book. It fits 74 A body with a 8 cyl engine. For some reason it is a different part number from the 73. Thanks for the help. Mike
Re: help me id this battery cable [Re: mopars4ever] #153456
11/20/08 02:30 PM
11/20/08 02:30 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
1974 A body with 8 cylinder
Re: help me id this battery cable [Re: mopars4ever] #153457
11/20/08 02:32 PM
11/20/08 02:32 PM
my cuda has the starter relay right next to the battery. in fact, it looks just like that cable
Re: help me id this battery cable [Re: mopars4ever] #153458
11/20/08 03:05 PM
11/20/08 03:05 PM
JohnRR Offline
JohnRR  Offline
they obviously changed something wit hthe way it's made to warrant the part number change
Re: help me id this battery cable #153459
11/20/08 05:46 PM
11/20/08 05:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Except E-body cables did not use the lower heat wrap
