Big block spark plugs? #1534291
11/17/13 10:22 AM
11/17/13 10:22 AM
Pa.
EvilScamp Offline OP
Pa.
I'm in the process of building a 383 for my Duster, i'd like to bump up to Platinum or even double platinum plugs for it but i'm having trouble locating them or even finding part numbers.
I'd like to stick to champion's if i can. Can anybody help with part numbers?
Re: Big block spark plugs? [Re: EvilScamp] #1534292
11/17/13 10:27 AM
11/17/13 10:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get a set of NGKs and be done with it.No need for fancy plugs.I run them in my 440 with 12.5 pistons on the street.Have them in the kids 413 also.Tried Champion and Autolite race plugs.The NGKs are way better.Rocky
Chrysler Firepower
Re: Big block spark plugs? [Re: therocks] #1534293
11/17/13 10:44 AM
11/17/13 10:44 AM
IN
ahy Offline
ahy  Offline
IN
I've had great luck with NGK's also. They stay cleaner than the others and keep working. Nominal life of a standard plug is what... 30k? You will probably be changing them first for some other reason so little benefit for platinum.
Re: Big block spark plugs? [Re: EvilScamp] #1534294
11/17/13 11:50 AM
11/17/13 11:50 AM
What Rock said, k.i.s.s. I ain't used NGK's but I've read (on here) nothing but good reviews on them. trick plugs are snake oil however trimming back the ground electrode but you keep enough bend so you can adj the gap(which unshrouds the flame kernel)/clocking the gap (there's a name for that)/experimenting with different gaps does work & the only trick I would consider trying is filing the center electrode to a point (that would drastically reduce their life but power is power). At the very least you want all edges sharp/not rounded (reduces arc over required voltage which is critical at higher RPM's when there's less time for coil saturation). Grab a point file (if you're old enough to know what they are ). To (really) kiss, NGK plugs gapped at .035" & regularly file the electode edges to keep em sharp, a little antisieze on the threads
Re: Big block spark plugs? [Re: RapidRobert] #1534295
11/17/13 11:59 AM
11/17/13 11:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
RR I have at least 4 points files.Just used one about a month ago to file the points in my J Deere lawn tractor.Rocky
Chrysler Firepower
Re: Big block spark plugs? [Re: therocks] #1534296
11/17/13 12:06 PM
11/17/13 12:06 PM
Rock I've always known we were (are) kindred spirits. I never forgot way back when the one guy got offended at you calling you kids kids. I used to be a goat farmer & a "kid" is a young goat & I wanted to tell him that my kids are my goats & my goats were my kids & I wanted to post that so bad (since it was true) but that would only have aggravated him (further) which is not what what I generally like to do unless I'm the person being messed with. I gotta go get some breakfast (& some coffee)
Re: Big block spark plugs? [Re: RapidRobert] #1534297
11/17/13 02:12 PM
11/17/13 02:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Hey RR I still have a SnapOn meter for points and dwell etc.Got it for 2 bucks from my brother at a garage sale.He just gave me a new analog Ohm/Volt meter also.Still in the box.It cost him a buck.I remember using them to read codes on the early computer car.Count the meter sweeps.LOL.Ill bet over 1/2 of the guys here never heard of that.I also have 2 sets of the adjusters for setting GM points where you opened the door and turned the screw.Been many years since Ive used it though.Rocky
Chrysler Firepower
Re: Big block spark plugs? [Re: therocks] #1534298
11/17/13 02:33 PM
11/17/13 02:33 PM
Pa.
Pa.
NGK copper or Platinum? All i ever used in my cars have been Champions never tryed anything else.
Re: Big block spark plugs? [Re: EvilScamp] #1534299
11/18/13 09:14 AM
11/18/13 09:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I got the race plugs for my aluminum heads.They were under 15 bucks for a set with shop discount.The 62 is sleeping or Id pull one and see what number the kids iron heads are.Rocky
Chrysler Firepower
Re: Big block spark plugs? [Re: EvilScamp] #1534300
11/18/13 01:53 PM
11/18/13 01:53 PM
We really need to know what type of heads, stock or aluminum aftermarket heads, compression ratio, type of fuel to be used and whatever else you want to share
Re: Big block spark plugs? [Re: Cab_Burge] #1534301
11/18/13 02:00 PM
11/18/13 02:00 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
It would be nice to have a chart to go by. There really doesn't seem to be too many plug options for the big blocks.
Re: Big block spark plugs? [Re: EvilScamp] #1534302
11/18/13 02:07 PM
11/18/13 02:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I used to drag race motorcycles, and at that time Champion made a plug that was quite a bit better than NGKs. It was a N2G, I think the G stood for gold, and it had a fine wire electrode.Worked great on the street also, but as I said they don't make it anymore. Just something to chew on.
Re: Big block spark plugs? [Re: EvilScamp] #1534303
11/18/13 02:35 PM
11/18/13 02:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would highly recommend to use standard NGK plugs in a 383 and not platinum or iridium plugs. Save yourself some money and heartache.
Standard plugs will last longer in our old engines. Those others are more designed for fuel injection where the motors run much cleaner, imo.
I found out the hard way years ago after spending some money and time to find out. My
Re: Big block spark plugs? [Re: EvilScamp] #1534304
11/18/13 02:40 PM
11/18/13 02:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
I just remembered that 383 uses the short reach plug, that might be why you can't find a part number for platinum plug? Might not make them in short thread?
I was using the 3/4 long reach plugs when I did my real world testing.
Re: Big block spark plugs? [Re: EvilScamp] #1534305
11/18/13 03:24 PM
11/18/13 03:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
NGK part no 3332.Not hard to find.Rocky
Chrysler Firepower
Re: Big block spark plugs? [Re: 71birdJ68] #1534306
11/18/13 03:28 PM
11/18/13 03:28 PM
Tri Cities TN area
Hailtheleaf538 Offline
Never Misses A Coffee Break
Tri Cities TN area
you didn't happen to race at Cherokee did ya?
Organized Labor: The people that brought you the weekend. If you can't grasp the meaning of the phrase "tongue in cheek", don't respond. 1970 H code Swinger, Top Banana 2012 Liberty Jet 4x4 True Blue Pearl
Re: Big block spark plugs? [Re: Hailtheleaf538] #1534307
11/18/13 03:47 PM
11/18/13 03:47 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello About spark plugs ,in our race cars and street cars we all run autolites , 86 in a hot motor and 85 in a cold motor , hot motor would be a race engine ,a cold motor is a street engine , never had any trouble. ( a real Mopar man)
Re: Big block spark plugs? [Re: Hailtheleaf538] #1534308
11/18/13 07:49 PM
11/18/13 07:49 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, I did race at Rogersville, first person in East Tennessee to run Nitrous in 81, and on a motorcycle.
Re: Big block spark plugs? [Re: mosweethemi] #1534309
11/18/13 10:08 PM
11/18/13 10:08 PM
With Autolites which plug is hotter, the 86 or the 85?
Re: Big block spark plugs? [Re: RapidRobert] #1534310
11/18/13 10:49 PM
11/18/13 10:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
86 is hotter than the 85.
i've used several kinds in my iron head b engines. my favorite has always been the champion j11y. it was designed for the mopar head. don't care much for the j10y or j12y. autolite 85's are a decent inexpensive plug. autolite 74's are o.k and motorcraft 42's work ok. i've used bosch 4036 platinums. i don't think they're any better or worse than anything else.
