copper dipped con rod #1534190
11/16/13 11:05 PM
11/16/13 11:05 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I was sorting out the parts on my spare T/A motor and wondered about this rod. It is completely covered in a thin layer of copper. The motor had several failures in its short life. It had rods from two different engines and two new rods. One was normal but the other was completely covered in copper. Even the rods bolts and nuts wee covered. The bearing surface and bushing were clean. Any ideas? All I could figure out that it may have been to add a little weight to balance it. IDK. It blasted off for the most part in my glass bead cabinet.
Re: copper dipped con rod [Re: fastmark] #1534191
11/16/13 11:08 PM
11/16/13 11:08 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The copper layer is used by the factory to get an out of spec rod back into spec.
Re: copper dipped con rod [Re: fastmark] #1534192
11/16/13 11:11 PM
11/16/13 11:11 PM
Kirkland, Washington
Pacnorthcuda Offline
They sometimes copper plated rods to get the bearing specs within tolerance.
Re: copper dipped con rod [Re: Pacnorthcuda] #1534193
11/17/13 12:00 AM
11/17/13 12:00 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
There were some 440 HP motor's in 70 that had a complete set of copper 6bbl rod's in them.
Re: copper dipped con rod [Re: thehemikid] #1534194
11/17/13 05:38 AM
11/17/13 05:38 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Some motors use copper to dissipate heat. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: copper dipped con rod [Re: astjp2] #1534195
11/17/13 09:31 AM
11/17/13 09:31 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
None of the bearing surfaces were coated so all it did was add weight.
Re: copper dipped con rod [Re: fastmark] #1534196
11/17/13 02:27 PM
11/17/13 02:27 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I have a set of these rods out of a 1973 340. My machinest says that he has seen and used thousands of these rods and it is not a concern.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: copper dipped con rod [Re: racealittle] #1534197
11/17/13 02:44 PM
11/17/13 02:44 PM
It seems to be more common on the 340 rods from the factory, I have several extra 340 rod now,both early and late forgings, one is coated the others are not If you want some more cores PM me $10.00 each plus the actual shipping costs
