Re: Who runs a solid cam on the street?
[Re: Mr.Yuck]
#153393
11/19/08 04:35 PM
11/19/08 04:35 PM
i do. hughes solid 565/576 lift 245/250 @ .050
runs great. the clacking makes you a little nervous but it goes away mostly once its good and warm (5 miles down the road). its harder to hear with the glasspacks tho
#153394
11/19/08 04:54 PM
11/19/08 04:54 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
.588 Comp solid in my 440 for the last 8 years.Great stick.Rocky
Chrysler Firepower
[Re: therocks]
#153395
11/19/08 05:10 PM
11/19/08 05:10 PM
I love them on the street!
I've run the MP .528 in a 440 and, IMO, there is no better street/strip cam!
Use some Crane iron rockers and you'll have a nice, reliable piece that makes awesome power.
[Re: 5spdcuda]
#153399
11/19/08 07:02 PM
11/19/08 07:02 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I built a cast crank 440 for my brother that has a small solid and big valve ported 452's.... headers and torker intake with edelbrock 750 = throttle response out the wazoo....... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: gch]
#153403
11/19/08 10:10 PM
11/19/08 10:10 PM
Posts: 7,664 IN
ahy
IN
I'm running a MM grind solid. 243@.050 and .55 lift in a 496 "B". I love it. Valve adjustment holds up well. Valvetrain upgrades (3/8 pushrods, comp pro magnum rockers) probably help keep it happy. There is a little more mechanical noise which I don't mind a bit.
[Re: 446acuda]
#153406
11/19/08 10:37 PM
11/19/08 10:37 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Worked real good on the street. It was an Ultradyne .590/.613 made for 440s in heavy cars.
Yes, mine was one of the heavy ones. 65 Plymouth Sport Fury at 4000 lbs. Drove it darn near everyday for 4 years.
Now, the Cuda is a different story. Some cams are just a plain b!tch on the street
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#153407
11/20/08 12:12 AM
11/20/08 12:12 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Sounds great, my minds made up then.... I like the looks of the Hughes profiles. The 4248 looks to be a good street strip piece. Do you guys think 10* locks & retainers are a must with solid lifter valvetrain that will see 6400 rpm?
