Rear main seals #1532693
11/12/13 06:58 PM
11/12/13 06:58 PM
USA
b54406barrel Offline OP
USA
So, my felpro full gasket set comes with all gaskets, seals, etc & and for the rear main, the seal halves and a tube of rtv. Not satisfactory. I go to the parts house & he orders a rear main kit for me. I tear it open and yup, the plastic collars are there for the bolts, the main seal halves, rtv, a couple of L-shape pieces of rubber too short to do any good and a couple of short pipe cleaners. What the heck happened to the side seals and what are you supposed to do with the pipe cleaners?
Re: Rear main seals [Re: b54406barrel] #1532694
11/12/13 07:10 PM
11/12/13 07:10 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Get some from a sponsor: http://www.superformanceproducts.com
Otherwise I don't remember. Use the search function.
Re: Rear main seals [Re: b54406barrel] #1532695
11/12/13 07:10 PM
11/12/13 07:10 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Think you are to load the pipe cleaners up with the RTV and jam them in the sides ..
Re: Rear main seals [Re: dynamite] #1532696
11/12/13 07:16 PM
11/12/13 07:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Winner, that's exactly what you are supposed to do.
Don't be the exception.
Re: Rear main seals [Re: Supercuda] #1532697
11/12/13 07:28 PM
11/12/13 07:28 PM
USA
USA
OK, thank you for the explanation. Appreciate the help!
Re: Rear main seals [Re: Supercuda] #1532698
11/12/13 07:45 PM
11/12/13 07:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No that's NOT what you are supposed to do!
I'll refrain from commenting on the competition's products. If you want to know more call them
I do appreciate the link help 68Killerbee
He'll be back when it's leaking again
Re: Rear main seals [Re: roadhazard] #1532699
11/12/13 08:03 PM
11/12/13 08:03 PM
USA
USA
Quite possibly but I wasn't going to 'brave' enough to try the pipe cleaner method. I rummaged and found some from one of my side oiler gasket sets that I never used. I think they'll work but if not, I'll give you a call.
Re: Rear main seals [Re: b54406barrel] #1532700
11/12/13 08:49 PM
11/12/13 08:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Ford side oiler?
No they won't work, totally different profile.
And I'm really not trying to be a "Richard Head"..... just messin with you guys a lil
Just for reference here are the retainer side seals I offer. Also offer the OEM rear seal with these as a kit.
Re: Rear main seals [Re: roadhazard] #1532701
11/12/13 09:09 PM
11/12/13 09:09 PM
A guy (on here) awhile back stuffed the sides with strings out of his mop & said it did not leak
Re: Rear main seals [Re: RapidRobert] #1532702
11/12/13 09:15 PM
11/12/13 09:15 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You are supposed to fill the sides with RTV, wet the pipe cleaners and stick it in. Its garbage don't do it. Get the rubber side seals, they're kind of a pain in the you know what to get in, so were the old fiber ones, this just requires a different technique since you can't tap these in. The don't make the fiber ones anymore because the secret ingredient to those is asbestos. Asbestos makes EVERYTHING work better but we can't have it anymore for obvious reasons.
Greg, have you considered making those side seals with something stiff in the middle so that they could be lubed up and tapped in like the old ones? I bought the side seals from a different source a while back (did use your gaskets for everything else though except my water pump), maybe yours install a little easier. The problem that I had was that mine wanted to slide up when sliding the retainer in. Had I had more time I could have glued them to the retainer, but just a thought I had.
PS everything Fel Pro sells seems to be garbage, buy Greg's gaskets or something from Victor and save yourself the aggravation. I was more than impressed with Greg's gaskets and will be using Superformance gaskets on anything I can in the future.
Re: Rear main seals [Re: GTX MATT] #1532703
11/12/13 09:46 PM
11/12/13 09:46 PM
USA
USA
Problem solved! A local Mopar man had a Mr. Gasket set so I'm covered! They are the side seals I remember, sort of a hard composite. Thanks again!
Re: Rear main seals [Re: b54406barrel] #1532704
11/12/13 10:37 PM
11/12/13 10:37 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Your golden
Re: Rear main seals [Re: GTX MATT] #1532705
11/12/13 10:45 PM
11/12/13 10:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
GTX Matt you nailed it on the head with the pipe cleaners. Maybe they should start buying some of mine
I can only assume you had used the "orange" retainer seals? The "blue" ones have been redesigned for a easier installation. Same material and basic profile just a color change for identification
Glad we were able to make you happy with the gaskets. It's nice we're considered a step above a very popular brand
Re: Rear main seals [Re: b54406barrel] #1532706
11/12/13 11:57 PM
11/12/13 11:57 PM
Central New York
bfury Offline
bfury  Offline
Central New York
My friend needs to replace his in a 413 RB in an Imperial. Is it worth trying to do with the engine in the car?
No Stock
Re: Rear main seals [Re: bfury] #1532707
11/12/13 11:59 PM
11/12/13 11:59 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yes, as long as you can drop the pan. It's easy.
Re: Rear main seals [Re: bfury] #1532708
11/13/13 09:34 AM
11/13/13 09:34 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If it still has the original rope seal it may be easier said than done.
Re: Rear main seals [Re: JohnRR] #1532709
11/13/13 11:43 AM
11/13/13 11:43 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I certainly would like to know the secret to success on the rear main seal. Frankly, every one I have ever installed has leaked. I have tried different brands of seals, different installation techniques, billet retainers, etc. But they all leak to varying degrees.
The only thing I haven't tried is The Right Stuff, which is the best sealant of it's type I have ever used.
I am just afraid that I won't be able to get it apart if use it.
Master, again and still
Re: Rear main seals [Re: DaveRS23] #1532710
11/13/13 11:49 AM
11/13/13 11:49 AM
that stuff is the cats' ass to get off but if it stops the leak You wont (have) to be back in there for quite awhile
Re: Rear main seals [Re: roadhazard] #1532711
11/13/13 12:07 PM
11/13/13 12:07 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Greg yeah they were the orange ones, I'll have to make sure I get those from you next time too
Re: Rear main seals [Re: b54406barrel] #1532712
11/13/13 12:08 PM
11/13/13 12:08 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
He doesn't know what he just gave up
