Has anyone used a 4.500 crank in a big block ?
#1532618
11/12/13 01:39 PM
11/12/13 01:39 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
Has anyone run this combo much and were you happy ? Any off the shelf pistons available ?
J.C. Childress
(434) 665-9541
Re: Has anyone used a 4.500 crank in a big block ?
[Re: JC Childress]
#1532619
11/12/13 08:11 PM
11/12/13 08:11 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
I freshen a 572 C.I. motor for a local racer several years ago, it was a cast iron World block with a 4.500 bore and stroke, Callies crankshaft and 7.100 BB Chevy type Comp Star rods. I think I had to do a small amount of grinding on the bottom of the block to make things clear, I made a oil crankscraper for it also ![](/ubbthreads/images/graemlins/thumbs.gif) It is still running around five years later, it is mainly a 1/8 mile car, runs low 6.0s at 109 MPH in a 3400 lb car, we only race half a year locally on every other weekend ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: JC Childress]
#1532621
11/13/13 12:23 AM
11/13/13 12:23 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I built one a long time ago, six pak rods, 4.5 stroke, welded stroker. There is room for everything but the oil pickup tube with a little grinding. A great build for a moderate street motor up to about 650 hp, or what ever you figure a stock block will handle. Absolutely killer torque with small port heads!
[Re: Jeepmon]
#1532623
11/13/13 06:52 AM
11/13/13 06:52 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I built one a while ago. With chevy 7.1 rods you can use a common "451" piston an get to zero deck with minor deck milling. It works well.
Plynouth VIP '67 TT IC EFI
[Re: dvw]
#1532625
11/13/13 10:26 AM
11/13/13 10:26 AM
JC Childress
Big Island ,VA
If you use the 4.500 crank in a stock block, is there any way that you can use the stock type pickup or do you have to use the remote lines and different pickup ?
J.C. Childress
(434) 665-9541
[Re: Dodgem]
#1532627
11/13/13 01:50 PM
11/13/13 01:50 PM
JC Childress
Big Island ,VA
Looking at options. I can get a 4.150 with Chevy journals real cheap or a 4.500 with Mopar journals real cheap.
Its just for a street cruiser...nothing fancy
J.C. Childress
(434) 665-9541
