Page 2 of 3 1 2 3
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Paul_Fancsali] #1531710
11/11/13 01:52 PM
11/11/13 01:52 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I have 340 mounts (no fit) aren't 67-72 318/360 mounts (the steel brackets) the same?
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531711
11/11/13 03:05 PM
11/11/13 03:05 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
the mounts on the block are different with on the driverside for some weird reason while passangerside they are all the same.
273/318 has a wider bracket
340/360 has a narrow version from my memory. seems like the only mounts/brackets for the later spoolmount system that can be found in partsstores is the wider 273/318 version and with 318 being the most common engine it sort of makes sence,since a simple nut or a few washers can be used as a spacer to make the wider brackets fit the narrow mounts on the 340/360block.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: 1Fast340] #1531712
11/11/13 08:59 PM
11/11/13 08:59 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Exactly what I was trying to get to
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: urdustd] #1531713
11/11/13 10:34 PM
11/11/13 10:34 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
YOU HAVE B/E MOUNTS PICTURED TRYING TO ATTACH TO YOUR BLOCK,THEY WOTN WORK WITH A-BODY, STEELS AND RUBBERS ARE DIFFERENT.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Joesixpack] #1531714
11/11/13 10:42 PM
11/11/13 10:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
273-318 A-BODY PASS SIDE MOUNTS SAME AS 340-360
DRIVER SIDE 273-318 A-BODY MOUNT IS ALL BY ITS LONESOME.
PASS SIDE PICTURED HERE
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Joesixpack] #1531715
11/11/13 10:45 PM
11/11/13 10:45 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
DIVERS SIDE a-body on left for 273-318
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Joesixpack] #1531716
11/11/13 10:47 PM
11/11/13 10:47 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
backside of pair
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Joesixpack] #1531717
11/11/13 10:59 PM
11/11/13 10:59 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Correct on that. If going into an A body car, those brackets won't work anyway.
The block having the high hole position at rear is going to be an issue with most 273/318 mounts which is what you need, not 340/360 mounts.
I have a mount bracket that will work with the high mount hole. $30 + shipping
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: RobX4406] #1531718
11/12/13 11:39 AM
11/12/13 11:39 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
340 resto blocks use 318 mounts...
Scott, I'll take that driver's side 340 motor mount bracket if you're going to toss it... :thumb
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: 1972CudaV21] #1531719
11/23/13 09:35 PM
11/23/13 09:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A fellow member graciously sent me a pair of A-body 318 mounts and the drivers side does fit as far as width goes, but it has the lower the rear mounting hole and my block will require the high mount hole style mount. RobX4406, did you get my PM? I need one!
Thanks!
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531720
11/24/13 10:48 AM
11/24/13 10:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If you use the correct mounts and insulaters they work fine.We done many resto blocks and never had an issue with the block bosses.Keep in mind the mounts must be the correct ones for the K-member as well.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: B G Racing] #1531721
11/24/13 12:52 PM
11/24/13 12:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bob, "correct mounts"? Which correct mounts are you referring to? I have several original 340 engines here for reference, as well as the Resto block. The blocks are not the same, the drivers side mounting boss is different on the Resto block so the "correct" E-body 340 mounts I have do not fit it. I realize that the different K-frames require different mounts, what I'm trying to determine is which mounts fit the resto block (which factory mounts from which year and engine combo will work on this block, in my case, for a 71 A-body). So, I have 70 E-body 340 mounts and they won't fit the block, I also have some A-body 67-72 318 mounts, which are the right width but the hole on the rear lug of the drivers side is too low so they don't fit either.
What cars/engine combos came with the drivers side mount that had the high mount hole mentioned a few posts above?
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531722
11/25/13 12:00 AM
11/25/13 12:00 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531723
11/25/13 12:40 AM
11/25/13 12:40 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Could you re-drill the mount to fit the block or is the new hole going to intersect the origional.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: dartman366] #1531724
11/25/13 12:53 AM
11/25/13 12:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is the bracket I just received (supposed to be a drivers side 67-72 273-318 mount).
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531725
11/25/13 01:01 AM
11/25/13 01:01 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ok, when you said lug I was thinking the lug on the block was too low,,nevermind
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: dartman366] #1531726
11/25/13 09:30 AM
11/25/13 09:30 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I will try and get some pictures and info on the mounts and block this weekend.The cars we worked with were 70 Cudas and challengers.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: B G Racing] #1531727
11/25/13 11:34 AM
11/25/13 11:34 AM
Guitar Jones Offline
Get some flat stock and weld a new ear to that bracket to match the lug on the block. Very easy to do.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: Guitar Jones] #1531728
11/25/13 11:40 AM
11/25/13 11:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure, always an options as a last resort, but with all of the posts on this thread that say "Oh no problem, just use "X" mounts, they work fine" I'd rather find one of those and bolt it on.
Re: 340 Resto Block Issues - Engine Mounts - Help! [Re: ScottSmith_Harms] #1531729
11/25/13 11:49 AM
11/25/13 11:49 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
What about the driver side bracket for a poly?
Page 2 of 3 1 2 3
