Page 2 of 7 1 2 3 4 5 6 7
Re: Intake gasket still leaking? [Re: Quicktree] #1530815
11/10/13 11:59 AM
11/10/13 11:59 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Tony, the first pic it looks like you have a valve cover bolt that was long enough to break into the port... Am I seeing that correctly?
Re: Intake gasket still leaking? [Re: Hot 340] #1530816
11/10/13 12:08 PM
11/10/13 12:08 PM
Q
Quicktree Offline OP
Q
good eye, I didn't see that i will go check. thanks
Re: Intake gasket still leaking? [Re: Quicktree] #1530817
11/10/13 12:11 PM
11/10/13 12:11 PM
in the middle
dodger mope Online content
dodger mope  Online Content
in the middle
take a look at your 2nd picture,the silicone is washed away at the bottom and there is a residue stream toward the valves.just a different look.
Re: Intake gasket still leaking? [Re: Hot 340] #1530818
11/10/13 12:17 PM
11/10/13 12:17 PM
Q
Q
that is exactly what that is, i found it on another hole also. but that is not a high oil place and the gasket surrounds the hole. but it's a hole none the less. good eye I never noticed that but I can't half see anyway.
Re: Intake gasket still leaking? [Re: dodger mope] #1530819
11/10/13 12:21 PM
11/10/13 12:21 PM
Q
Q
true but even if the gasket is leaking it would not explain the oil build up after the motor is off would it? there is way over an ounce on all valves that are closed.
Re: Intake gasket still leaking? [Re: Quicktree] #1530820
11/10/13 12:21 PM
11/10/13 12:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do I see silicone there? Was always told silicone and fuel = and I usually use Gaskasinch myself............
Re: Intake gasket still leaking? [Re: Thumperdart] #1530821
11/10/13 12:25 PM
11/10/13 12:25 PM
Q
Q
could be, I think I may have put a skim coat around the port this time to see if that may help the seal. i have heard that before.
Re: Intake gasket still leaking? [Re: Quicktree] #1530822
11/10/13 12:32 PM
11/10/13 12:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m no expert(if u saw me you`d agree)but it`s never worked for me and we never used it at Pettis except for on the end rails AFTER curing for 24+ hrs.
Re: Intake gasket still leaking? [Re: Thumperdart] #1530823
11/10/13 12:36 PM
11/10/13 12:36 PM
Q
Q
it was on the end rails, I have used a thin skim coat before and never had a problem. but I do understand why it isn't used. the fuel really never gets on the gasket once it has been tightened down?
Re: Intake gasket still leaking? [Re: Quicktree] #1530824
11/10/13 12:37 PM
11/10/13 12:37 PM
in the middle
in the middle
the way to explain the excess oil on the valves is think of a lot of oil in the manifold, and with the engine shut down the oil just runs down hill to the valves
Re: Intake gasket still leaking? [Re: Quicktree] #1530825
11/10/13 12:40 PM
11/10/13 12:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Who knows, may not even be the problem but years ago Cab showed me the importance of manifold measuring and fitting and it`s way more critical than some may think.
Re: Intake gasket still leaking? [Re: Thumperdart] #1530826
11/10/13 12:42 PM
11/10/13 12:42 PM
Q
Q
yea i know, guess i'll have to send the heads and intake off to get checked
Re: Intake gasket still leaking? [Re: Quicktree] #1530827
11/10/13 12:45 PM
11/10/13 12:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You need to do it yourself on the motor no way a machinest would know what to do. It`s not that hard but critical ESPECIALLY the angles between the intake and head face. Jew can do it.............
Re: Intake gasket still leaking? [Re: Thumperdart] #1530828
11/10/13 12:50 PM
11/10/13 12:50 PM
Q
Q
ok how?
Re: Intake gasket still leaking? [Re: Quicktree] #1530829
11/10/13 12:57 PM
11/10/13 12:57 PM
Delray beach, Florida
P
Performance Only Offline
P
It sounds like it's time to clean off all the gasket material and check the fit of the intake with feeler gauges. Another way to do it is with clay. Either way will show up any problems.
You can't always assume that because the heads have the proper intake face angle that the block is a true 90 degrees. The opposite is also true.
machine shop owner and engine builder
Re: Intake gasket still leaking? [Re: Performance Only] #1530830
11/10/13 01:03 PM
11/10/13 01:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THIS.............Go get em tiger..........
Re: Intake gasket still leaking? [Re: Performance Only] #1530831
11/10/13 01:22 PM
11/10/13 01:22 PM
Q
Q
I just talked to the previous owner he said he used one of your favorite cleaning wheels to get the old gaskets off before he seen your post but didn't think he took any material off. want to explain how to check? are you by your phone?
Re: Intake gasket still leaking? [Re: Thumperdart] #1530832
11/10/13 01:28 PM
11/10/13 01:28 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If all the above fails,try enlarging you bolt sizes a size or two.After doing all of the above and more with no results,enlarging the holes a size or two has cured the problem for me on several intakes.I had to do it on my LD Indy Tunnel-Ram intake that with the top carb.plate off the intake ports lined up perfect and the bolt holes looked perfect but were off just enough to cause the problem.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Intake gasket still leaking? [Re: Quicktree] #1530833
11/10/13 01:35 PM
11/10/13 01:35 PM
in the middle
in the middle
with this information,maybe you can find low spots with a straight edge?
Re: Intake gasket still leaking? [Re: dodger mope] #1530834
11/10/13 01:36 PM
11/10/13 01:36 PM
Q
Q
thats what I am doing now.
