Re: Any Neon owners??
[Re: reflections7]
#153026
11/18/08 08:59 PM
11/18/08 08:59 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
change the radiator now before it crosses fluids, i sell a ton of them and the only thing that kills them at any mileage is the junk factory plastic rad coming unglued and mixing collant with trans fluid then trans blows. keystone sells them to me for 90.00
MOPAR OR NO CAR
[Re: wingman]
#153028
11/18/08 10:15 PM
11/18/08 10:15 PM
Is the radiator deal only on the later ones because I have two first gen's, a 98 & 99. Wouldn't it be cheaper to just use an external cooler. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
#153030
11/18/08 10:34 PM
11/18/08 10:34 PM
hemigod426
2000-2005 cars, there is really no room for seperate trans coller, and you will still loose coolant. 2000,01,02, top tank, 2003,04,05 lower tank
MOPAR OR NO CAR
[Re: wingman]
#153031
11/18/08 11:53 PM
11/18/08 11:53 PM
Posts: 2,431 USA
SSAAHemiFan
USA
DAMHIK
![](/ubbthreads/images/graemlins/iagree.gif)
Just went thru this with mine. Only had 42K miles on it. I flushed the trans and the block out and so far the trans is still alive .
[Re: Quikshft]
#153039
11/19/08 11:05 PM
11/19/08 11:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
When I traded in my 05, wish I hadn't, I had zero problems with it, but it was a stick car. About 46k miles on it, ran great.
