Re: CNC porting [Re: RAMM] #1529234
11/07/13 11:53 AM
11/07/13 11:53 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I don't see how that is possible considering the Eddy's are two seperate castings with the pushrod hole machined in a different position. This is probably why your center divider is thin-because they are std. port Victors. J.Rob
The same rocker is used for both heads so I don't see how the pushrod hole could be different. I've never had std port and a MW port head next to one another to compare though.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: CNC porting [Re: d7cook] #1529235
11/07/13 12:02 PM
11/07/13 12:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All I can add is that T&D now specifies two different part #s for Victor heads depending on MW vs. standard, and the MW version uses an intake rocker w/ more offset.
Re: CNC porting [Re: BradH] #1529236
11/07/13 12:17 PM
11/07/13 12:17 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
OK, you're right then the MW pushrod hole must be moved .075" outboard I assume. When I bought these heads I think the MW version had just come out.
Re: CNC porting [Re: BradH] #1529237
11/07/13 12:31 PM
11/07/13 12:31 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Eddy Victors.
Standard-size port or Max Wedge?
They are the standard ports. One of the ports has been opened up to Max Wedge size so the rest will need to be done.
Combination details? I'm asking because I did some research into what CNC offerings are out there for Victors (not many) and what I did find was predominantly for MW-sized ports anyway.
Some seemed focused more on big high-lift #s (e.g. Speier Racing Heads), whereas the Hughes program seems more oriented to more moderate lift requirements.
The combination will be a 500", 12-1 with about a 670 lift solid.
Re:MCH CNC ported 440-1 VS Eddy M.W.Victor [Re: RAMM] #1529238
11/07/13 03:33 PM
11/07/13 03:33 PM
I have both sets of heads in this picture, CNC ported 440-1 and a stock unported set of Victor M.W.
Stock unported Eddy M.W.Victor. [Re: Cab_Burge] #1529239
11/07/13 03:36 PM
11/07/13 03:36 PM
This may be a better picture of the stock Eddy Victor M.W. intake ports showing the stock divider
