Clutch Pedal #1529181
11/05/13 09:12 PM
11/05/13 09:12 PM
Scatchamatoon
Saskabusa Offline OP
Scatchamatoon
I am looking into swapping an A-833 into a 74 Roadrunner with a 727. What years of pedal should i look for. Are they the same 71 to 74 or are there any differences through the years?
1974 Roadrunner
1967 Charger
Re: Clutch Pedal [Re: Saskabusa] #1529182
11/06/13 11:22 AM
11/06/13 11:22 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
There are some slight differences through the years 71-4, however any of those years will work. If you happen to find a 70-4 E set, you can swap the pedals into your hanger bracket. Pedals are the same. We make a pedal set if you cant find what your looking for at a reasonable price.
http://www.brewersperformance.com/products.asp?cat=250
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
