Re: hard starting hot not heat soak
[Re: moparmikethree]
#1529115
11/05/13 08:10 PM
11/05/13 08:10 PM
Posts: 88 KS.
HairOtheDog
KS.
just got done with my 410 stroker, runs really great when on a good drive turn it off and try to restart right away. cranks slow starter draging.. Is this because the timming is advanced too far?
You running headers?
#1529116
11/05/13 08:15 PM
11/05/13 08:15 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Timing would be my starting point.
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
#1529119
11/05/13 08:29 PM
11/05/13 08:29 PM
RapidRobert
Hello Michael, Take the coil secondary wire out of the dist & ground it & retry it & that'll tell you immediately if it is from too much initial. If that ain't it then (1) faulty starter (2) starter getting too hot (3) too small of cables (common with batt in trunk/extremely rare with batt up front) (4) poor connection on the large cable circuit including the positive from batt post to starter & starter back to block/block to batt neg post. (5) Way way less likely would be excessive ring drag (6) bad batt (sulphated or bad cell)
[Re: Magnum]
#1529121
11/06/13 07:47 AM
11/06/13 07:47 AM
Posts: 1,567 Ky
jt4406
Ky
If the timing isn't the issue (you disconnect the coil wire and it still cranks slow), get a voltmeter (analog is easier, sweeping needle easier to read) and connect it to Each End of the circuit you want to test, then crank the engine. The reading on the voltmeter WHILE the engine is cranking is the voltage you are loosing in that circuit. (If the needle tries to go backwards, switch your leads around) Ex: connect voltmeter to postiive battery cable at the battery and positive battery cable end at the starter, crank engine, voltage shown is lost traveling through only the positive cable. Common Voltage Drop test. Do this at each circuit and connection. Another ex: Hooking the voltmeter to the positive (or negative) cable at the battery and holding the other lead securely to the Same Post and cranking the engine will show voltage lost at that connection (dirty batt cables). None should exceed 1/2 volt. Hope this helps. Jess
Yeah, it's hopped up to over 160...
#1529125
11/07/13 10:33 PM
11/07/13 10:33 PM
RapidRobert
Mike, any news? I'm going to take a WAG & say "starter"
