Re: Recommenfations on torsion bars and shocks please
[Re: Tomswheels]
#1528376
11/07/13 02:02 AM
11/07/13 02:02 AM
Posts: 22,772 Bitopia
jcc
Bitopia
Gee, wonder why a rear bar was a problem?
I believe when you stop the rear from leaning, you stop what little weight is in the rear from transferring to the outside tire. The rear stepped out much earlier with the rear bar.
Not sure if I understand your point, but a rear bar for instance will decrease the loading on the inside tire, AND increase loading on outside tire, resulting in less total axle grip BECAUSE tires are LESS evenly loaded, and this results in increased over steer, and if not matched better to front roll resistance, handling is perceived to be degraded.
[Re: PHJ426]
#1528379
11/08/13 11:22 AM
11/08/13 11:22 AM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
You can also find scales at landscaping companies, drywall suppliers, waste transfer stations, and I'd imagine, some freight companies that are boxing loads in/out of the docks.
To take a wild stab at it, I'd bet your car is around 3200# with a 56% front bias, or roughly 1800# on the nose. So a 10# figure for that would be 180# t-bar rate, or just a hair under 1". For simplicity, call it 1" and your good.
If this is a bucks down approach then pick up a solid 1.125" front sway bar, bolt it all together and see how it feels.
[Re: cudazappa]
#1528380
11/08/13 02:27 PM
11/08/13 02:27 PM
jcc
Bitopia
JCC You got it backwards. You want your weight to transfer to the outside in a corner. That's where you need the grip, not the inside.
We disagree, anybody want to jump in here, I think this is a major misunderstanding here, or one of us is completely wrong ( I don't mean that in belligerent way)
A couple of basics regarding grip as I see them, a. maximum grip is achieved on a single axle is when both tires are loaded exactly the same. In a corner that is not possible, no matter what the design or features. b. Any difference in tire loading reduces overall total grip, no matter what the weight transfer, as the higher loaded tire DOES NOT gain the grip back proportionally that the unloaded tire lost. c, sway bars reduce grip to a degree by increasing tire loading differences, but may have other offsetting positives by such things such as improved wheel/tire alignment in body roll. d. on this point I am winging it, but body roll is possibly additionally increased by removing sway bars because of increased grip, if tire alignment can still be useful. e. there is more to perceived handling then ultimate grip.
Well?
[Re: jcc]
#1528381
11/08/13 06:05 PM
11/08/13 06:05 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Don't forget about preventing brake dive, larger torsion bars help prevent this. I have 1.03's on my b-body but I am thinking I need to go larger because of my heavy world block and other heavy parts that I am installing. TIm
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
