1969 saddle interior paint codes??? #1528348
11/03/13 11:42 PM
11/03/13 11:42 PM
Oologah, Oklahoma
Big Squeeze Offline OP
Oologah, Oklahoma
1969 Plymouth with T7 exterior...changing from black to saddle interior...
What's the paint code for the dash?? Is it textured or suede?
I'm assuming the upper and lower door frames are T7 bronze?? Gloss??
If you can't handle the truth, you're living a lie.......
Re: 1969 saddle interior paint codes??? *DELETED* [Re: Big Squeeze] #1528349
11/05/13 12:22 AM
11/05/13 12:22 AM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
Post deleted by WORKER_BEE
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: 1969 saddle interior paint codes??? [Re: WORKER_BEE] #1528350
11/05/13 01:56 AM
11/05/13 01:56 AM
Manitoba, Canada
fjmg Offline
fjmg  Offline
Manitoba, Canada
Both of my T5 69's with C6T interiors have T3 as upper door frame codes. I think T3 was used as it is close to saddle tan interior.
Re: 1969 saddle interior paint codes??? [Re: fjmg] #1528351
11/05/13 09:32 PM
11/05/13 09:32 PM
WORKER_BEE Offline
WORKER_BEE  Offline
I deleted my first post so I can start over.
Going by the '69 FSM, exterior gloss finish colours were used on the door and quarter upper inner frames, garnish moldings and "B" pillars. In your case it would be T7 Ditzler #2032.
If this was a '69 Charger, it would be a lighter colour. The SFM says Y4.....but T3 sounds more correct.
The dash, steering column, etc.... it would be suede Buckskin Tan Ditzler #23076
Re: 1969 saddle interior paint codes??? [Re: WORKER_BEE] #1528352
11/06/13 01:37 AM
11/06/13 01:37 AM
Oologah, Oklahoma
Oologah, Oklahoma
Thank you!!!!
Re: 1969 saddle interior paint codes??? [Re: Big Squeeze] #1528353
11/07/13 07:20 PM
11/07/13 07:20 PM
our early built 69 GTX vert has a more yellowish gold colored steel dash and column than the buckskin brown. Mopaints (who has not gotten back to us in quite some time) was supposed to send out a sample of what they called Majestic Gold which was a 68 color and could possibly have been used on our car since our car had a SPO date of 10/3/68 which could also explain why the buckskin brown was too dark.
