Re: lil disappointed [Re: 493_DART] #1528191
11/03/13 10:16 PM
11/03/13 10:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i agree with most--- 4500 or so stall , and shift it lower = try 6500 . my 493 likes just under 6k !
is that the Hughes cam ??? i have that same one
this guy is running my 4000 stall I had in my car and he shifts under 6k just like I use to.
Re: lil disappointed [Re: hemi-itis] #1528192
11/03/13 10:38 PM
11/03/13 10:38 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
The part that gets me is it wakes up 100 feet out
How's the timing curve set up? Are you data logging or reading plugs?? At that weight the 60 should be low 1.4 or maybe high 3's
at this point I haven't really tried any changes,dist is firecore otb,haven't pulled a plug yet,i was racing my other car and just took this one to put some passes on motor.the sr;s are standard port size.i will get a handle on it in the spring,i guess I was thinkin it was going to be way faster than the 440 I pulled out[10.80's@125].
Re: lil disappointed [Re: sam64] #1528193
11/03/13 11:01 PM
11/03/13 11:01 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
There was only one good run in the track Saturday that was the first run. Went slower every pass after. Depending on what time you ran it got worse. I read my logger every run. Your setup may be just fine.
Shawn Jennings
Re: lil disappointed [Re: sixpackgut] #1528194
11/03/13 11:05 PM
11/03/13 11:05 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
actually ray--- it flashes to 4500 in my car !
thats what i leave at---no 2 step--just mash the gas with the T brake on
Re: lil disappointed [Re: sam64] #1528195
11/03/13 11:24 PM
11/03/13 11:24 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
i'm only leaving at 2200 on the foot brake,its starts pushing with anymore rpm.the 31.5 tire on it now is way shorter than the 32's I had on it.cab,i don't think it's loading up it doesn't bog per say.it almost feels like when you hit passing gear,it pulls that much harder at about 100 feet out.i forgot to take my gopro would been helpful to see what the tach showed.time to put it to bed for winter.
Just re-read this thread and noticed your statement about 2200RPM or it starts pushing. Something wrong there!! Are the brakes bled good? If so, convertor is not near right. And the 100' take off makes me think the convertor is toast too.
If you like drag racing, support your local track.
Re: lil disappointed [Re: 493_DART] #1528196
11/03/13 11:26 PM
11/03/13 11:26 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
At least a 5000 stall convertor.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: lil disappointed [Re: 572_dup2] #1528197
11/03/13 11:27 PM
11/03/13 11:27 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
shawn I made 4 hits through out the day 10.25-19-21-19,i made the last pass at 3:03 as my 63 was picking up et,i had a good time.saw some old friends,my old race car[jeff flocks car]and came home with both cars in one piece.
Re: lil disappointed [Re: sam64] #1528198
11/04/13 12:57 AM
11/04/13 12:57 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
With the std. Port and the cam you are running in a 500+ inch engine 7000 rpm is going to be way past the power peak. Possibly you need to check the accuracy of your tach.
Getting old just means you were smarter than some and luckier than others.
Re: lil disappointed [Re: Cab_Burge] #1528199
11/04/13 12:33 PM
11/04/13 12:33 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Is it loading up do to much accellerator squirter or loading up from the carb.? I've seen similar results with to much squirter, ended up swapping out the rear 50CC pump and pump arm to a 30 CC pump and arm and went down to # 29 or #31 squirters, depending on winter or summer racing It should really snap off the line, even with that converter
I think Cab is correct I went from a 1050 carb to a 1020 on one of my cars which had a 1.46 60 foot and went to 1.30 first time out! Nothing else was changed.
Re: lil disappointed [Re: poisondart2] #1528200
11/04/13 02:41 PM
11/04/13 02:41 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Could be too big of a pump shot killing the hit. But pushing through the brakes at such a low rpm plus the slow 60' times are symptoms of a bad stator in the converter. Sometimes this stuff will make you want to pull your hair out.
Re: lil disappointed [Re: Cab_Burge] #1528201
11/04/13 04:57 PM
11/04/13 04:57 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
This looks like something to try in the spring
Is this a new build if so I've seen motors start breaking in with about 15 passes on the combo so maybe more runs will get you what you're looking for
Great job at least you came home with everything together
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: lil disappointed [Re: 67mprfan] #1528202
11/04/13 08:02 PM
11/04/13 08:02 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
yes it's a new motor 6 passes on it now,i will start tuning on it in the spring if I don't sell it first.
Re: lil disappointed [Re: ProSport] #1528203
11/05/13 08:15 AM
11/05/13 08:15 AM
gregsdart Offline
gregsdart  Offline
Maybe it's just me but I would be looking more at 5000-5200 on the converter...
I agree also, 5000+ custom built converter for your combo, keep your 4.30's, need to get that 60 foot down and the rest of the ET will come down with it.
Nice car and it runs good, you will easily hit 9's as you've only made 6 passes so far.
I agree the converter is too tight. Shoot for 5,000 minimum, or 1300 rpm below shift point. You might want to try shifting at 6700 to 6800. I had a 499 with 440-1 heads, bowl work only on them, 283/290/110 solid roller, went 9.50s with a Dominater shifting at 6800. Part of the problem may well be the fuel curve of the carb. With a wide rpm spread and a big carb, It may very well be lean on the bottom and go richer as it rpms. Also, there is a lot of power in porting, which ought to be done at the same time as the converter selection. Once dialed in, your car ought to go 9.50s or better. That only takes about 725 hp, which is very reachable. Right now, using a 10.10 ET (better match to the MPH) I came up with only 595 hp on that run. There is a lot to get right, and then you will fly.
Re: lil disappointed [Re: gregsdart] #1528204
11/05/13 09:23 AM
11/05/13 09:23 AM
tboomer Online work
tboomer  Online Work
First of all let me say that car is a dandy! Very nice!! I also think that a better converter will help you. My junk has had a best of 1.386 60' but usually is in the 1.39 to 1.41 range. It also weighs over 3500# with the driver and has run 10.15 at almost 131 mph. We do need more jet in it. My heads are MW ports and a small roller. Keep looking I know you will find it! Good luck!! Ted
Re: lil disappointed [Re: tboomer] #1528205
11/05/13 12:25 PM
11/05/13 12:25 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
There's a 5200 stall 8" ATI in the race parts section for $450 on page 6. Not mine but I thought I'd let you know. I paid over $800 for mine new.
Re: lil disappointed [Re: ProSport] #1528206
11/05/13 05:10 PM
11/05/13 05:10 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
thanks for the heads up on the converter,but I will have one built for my combo if I keep the car.
Re: lil disappointed [Re: sam64] #1528207
11/05/13 08:38 PM
11/05/13 08:38 PM
Penna
70satelliteguy Offline
Penna
If this is a new combination where is the cam installed at?
Re: lil disappointed [Re: sam64] #1528208
11/05/13 10:37 PM
11/05/13 10:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i too am in the 4800-5000 stall camp.
but, i also think the speed is a bit low for your ET goals.
i would suggest opening the heads up to MW size and running a bigger manifold(Indy 400-3) to compliment the added stall.
