Re: lil disappointed
[Re: hemi-itis]
#1528192
11/03/13 10:38 PM
11/03/13 10:38 PM
Posts: 1,285 okla.
sam64
okla.
The part that gets me is it wakes up 100 feet out How's the timing curve set up? Are you data logging or reading plugs?? At that weight the 60 should be low 1.4 or maybe high 3's
at this point I haven't really tried any changes,dist is firecore otb,haven't pulled a plug yet,i was racing my other car and just took this one to put some passes on motor.the sr;s are standard port size.i will get a handle on it in the spring,i guess I was thinkin it was going to be way faster than the 440 I pulled out[10.80's@125].
[Re: sam64]
#1528193
11/03/13 11:01 PM
11/03/13 11:01 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
There was only one good run in the track Saturday that was the first run. Went slower every pass after. Depending on what time you ran it got worse. I read my logger every run. Your setup may be just fine.
Shawn Jennings
[Re: sixpackgut]
#1528194
11/03/13 11:05 PM
11/03/13 11:05 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
i agree with most--- 4500 or so stall , and shift it lower = try 6500 . my 493 likes just under 6k !
is that the Hughes cam ??? i have that same one
this guy is running my 4000 stall I had in my car and he shifts under 6k just like I use to.
actually ray--- it flashes to 4500 in my car !
thats what i leave at---no 2 step--just mash the gas with the T brake on
[Re: 493_DART]
#1528196
11/03/13 11:26 PM
11/03/13 11:26 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
At least a 5000 stall convertor.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: 572_dup2]
#1528197
11/03/13 11:27 PM
11/03/13 11:27 PM
Posts: 1,285 okla.
sam64
okla.
shawn I made 4 hits through out the day 10.25-19-21-19,i made the last pass at 3:03 as my 63 was picking up et,i had a good time.saw some old friends,my old race car[jeff flocks car]and came home with both cars in one piece.
[Re: sam64]
#1528198
11/04/13 12:57 AM
11/04/13 12:57 AM
Posts: 5,160 Texas
dannysbee
Texas
With the std. Port and the cam you are running in a 500+ inch engine 7000 rpm is going to be way past the power peak. Possibly you need to check the accuracy of your tach.
Getting old just means you were smarter than some and luckier than others.
[Re: Cab_Burge]
#1528199
11/04/13 12:33 PM
11/04/13 12:33 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
Is it loading up do to much accellerator squirter or loading up from the carb.? I've seen similar results with to much squirter, ended up swapping out the rear 50CC pump and pump arm to a 30 CC pump and arm and went down to # 29 or #31 squirters, depending on winter or summer racing It should really snap off the line, even with that converter
I think Cab is correct I went from a 1050 carb to a 1020 on one of my cars which had a 1.46 60 foot and went to 1.30 first time out! Nothing else was changed.
[Re: 67mprfan]
#1528202
11/04/13 08:02 PM
11/04/13 08:02 PM
Posts: 1,285 okla.
sam64
okla.
This looks like something to try in the spring
Is this a new build if so I've seen motors start breaking in with about 15 passes on the combo so maybe more runs will get you what you're looking for
Great job at least you came home with everything together
yes it's a new motor 6 passes on it now,i will start tuning on it in the spring if I don't sell it first.
[Re: ProSport]
#1528203
11/05/13 08:15 AM
11/05/13 08:15 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Maybe it's just me but I would be looking more at 5000-5200 on the converter...
I agree also, 5000+ custom built converter for your combo, keep your 4.30's, need to get that 60 foot down and the rest of the ET will come down with it. Nice car and it runs good, you will easily hit 9's as you've only made 6 passes so far.
I agree the converter is too tight. Shoot for 5,000 minimum, or 1300 rpm below shift point. You might want to try shifting at 6700 to 6800. I had a 499 with 440-1 heads, bowl work only on them, 283/290/110 solid roller, went 9.50s with a Dominater shifting at 6800. Part of the problem may well be the fuel curve of the carb. With a wide rpm spread and a big carb, It may very well be lean on the bottom and go richer as it rpms. Also, there is a lot of power in porting, which ought to be done at the same time as the converter selection. Once dialed in, your car ought to go 9.50s or better. That only takes about 725 hp, which is very reachable. Right now, using a 10.10 ET (better match to the MPH) I came up with only 595 hp on that run. There is a lot to get right, and then you will fly.
[Re: tboomer]
#1528205
11/05/13 12:25 PM
11/05/13 12:25 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
There's a 5200 stall 8" ATI in the race parts section for $450 on page 6. Not mine but I thought I'd let you know. I paid over $800 for mine new.
[Re: ProSport]
#1528206
11/05/13 05:10 PM
11/05/13 05:10 PM
Posts: 1,285 okla.
sam64
okla.
thanks for the heads up on the converter,but I will have one built for my combo if I keep the car.
[Re: sam64]
#1528208
11/05/13 10:37 PM
11/05/13 10:37 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i too am in the 4800-5000 stall camp.
but, i also think the speed is a bit low for your ET goals.
i would suggest opening the heads up to MW size and running a bigger manifold(Indy 400-3) to compliment the added stall.
