Re: Dual quad air cleaner pics? What are you using? P
[Re: WO23Coronet]
#1802954
04/14/15 12:42 AM
04/14/15 12:42 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This is what the stock 1962 300H 413 used; Greg The 60 Dodge I'm buying comes with a complete long ram setup but it also comes with a set of those air cleaners that I may put on an Edelbrock CH28 with some Carters instead of the long ram, can you still get filters? Possibly !
Re: Dual quad air cleaner pics? What are you using? Pics?
[Re: CrAzYMoPaRGuY]
#1802967
04/14/15 12:53 AM
04/14/15 12:53 AM
62maxwgn
Blair County,PA
Well, oddly enough I will be building the exact same air cleaner soon for my Jensen Interceptor. I have a CH28 Edelbrock #5440, and I'm going to run an oval Mopar air cleaner on it. I'll post pics when I start... I have already made other unusual air cleaners, it's not THAT hard, just takes a little planning.... Remember,if you are running a CH28 and want to use the oval air cleaners,you have to run AFB's.Also there will be no clearance between the air cleaners,the carb spacing is about 3/8 closer than the factory intake. Here is my factory intake,everything from a 62 300H,
[Re: 62maxwgn]
#1803271
04/14/15 02:41 PM
04/14/15 02:41 PM
Posts: 4,269 Canada
WO23Coronet
Canada
Well, oddly enough I will be building the exact same air cleaner soon for my Jensen Interceptor. I have a CH28 Edelbrock #5440, and I'm going to run an oval Mopar air cleaner on it. I'll post pics when I start... I have already made other unusual air cleaners, it's not THAT hard, just takes a little planning.... Remember,if you are running a CH28 and want to use the oval air cleaners,you have to run AFB's.Also there will be no clearance between the air cleaners,the carb spacing is about 3/8 closer than the factory intake. Here is my factory intake,everything from a 62 300H, Can you use AVS's on the CH28?
[Re: 62maxwgn]
#1803324
04/14/15 03:43 PM
04/14/15 03:43 PM
Posts: 4,269 Canada
WO23Coronet
Canada
Are the air horns different sizes?(think they're the same) or is there some sort of interference? (Linkage etc)
