Elec. diagram for my radio, help
#1527509
11/02/13 06:11 PM
11/02/13 06:11 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
I have a factory AM/FM/Cassette radio for my pickup (I think it's stock for LRE's). Just need a little help as to what wires go where (or if someone has a diagram, could you post it?). The power plug: I know the orange wire goes to the lighting. The red is power. I'm guessing the case grounds the unit. In the speaker wiring plug: I have a yellow wire, and a white wire in one row (side by side). A violet wire, and green wire in the next row, and one black wire (ground?). But here's where I'm in need of some help. All by it's self is a yellow W/black stripe wire (the one sticking up in the pic). What's this for? Here's a pic. Thank you in advance! ![](/ubbthreads/images/graemlins/thumbs.gif) ![](http://i51.photobucket.com/albums/f355/duster416/Wiringformyam-fm-cassetteradio002_zps2ad050ce.jpg)
Re: Elec. diagram for my radio, help
[Re: I_bleed_MOPAR]
#1527511
11/02/13 09:23 PM
11/02/13 09:23 PM
bigblock340power
Elk Grove, Calif.
HTH
http://www.mymopar.com/index.php?pid=24
Tim
Thank you for that info. I saved it to my files. One thing I'm not sure of, is why they would have a wire going to the tail lamps from a radio? In the diagrams, it shows different radios than I have (one with a CB, or 8tack. Mine has a cassette deck), but still have the yellow/blk stripe wire. I guess it goes to the same place as the ones in the diagrams. So, I guess the concept is the same. Still, I am a bit stumped.
[Re: poorboy]
#1527514
11/05/13 02:53 AM
11/05/13 02:53 AM
bigblock340power
Elk Grove, Calif.
I'm thinking the yellow with a black tracer might be the power for a power antenna? Gene
Hummmmmmmmmmmmmmm, odd way to get power for that. But who knows !
