Re: Dynomax VT mufflers?
[Re: demon]
#1527377
11/02/13 12:10 PM
11/02/13 12:10 PM
Quiet at idle is how they would sound. Friend has a set on his late model hemi ram and you hear nothing until it is opened up.
[Re: demon]
#1527378
11/02/13 04:19 PM
11/02/13 04:19 PM
Posts: 8,451 Highland, MI.
Sunroofcuda
Highland, MI.
From everything I've read, they rattle & it is VERY annoying. Dynomax head engineer told me the rattle was fixed, but people running them say otherwise.
Moving parts inside a muffler = cool concept, bad idea.
[Re: BigDawg72]
#1527381
11/02/13 10:42 PM
11/02/13 10:42 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
We have played with many sets now. In some cases, you can't hear anything rattling. It depends upon camshaft, compression and size. We have them on a 410 with 10:8 compression and a really big cam. They only slightly thump but the noise of the exhaust pinging through the headers is far worse. The way they quiet and eliminate roar and drone is far better then the little bit of noise they make at idle sometimes.
The wire mesh you see silences the closing thump but as they flap violently, the other side may clatter. Again, big cams, big engines, big compression = thump/rattle.
Not all cars work as well but in our case, they are great. On Dad's 480 cu in Pontiac, they did clank a bit but Walker recommends against the big engine, high compression, big cam set ups.
They are truly great mufflers and since they have a sound guarantee, you have nothing to lose but a bit of time and labor trying them. I say give them a shot if your engine fits the requirements.
Tom
[Re: demon]
#1527386
11/03/13 11:42 PM
11/03/13 11:42 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have a pair on order for small block. If they do not work, I will go to stock mufflers. I cannot stand the drone on the Dynomax on the car now at hiway speeds. Mine could be rattling now but I could not tell.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Tom Hand]
#1527387
11/04/13 09:42 AM
11/04/13 09:42 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The part number 17138 OFFSET Camaro style, has quite a different case due to opposing outlets Would it also have an advantage surppressing rattle? http://www.dynomax.com/mufflers.php?muffler=vt
