valve spring strength for mushroom flat tappet cam
#1526979
11/01/13 02:47 PM
11/01/13 02:47 PM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
In the process of rebuilding a 1969 Grand National NASCAR HEMI, I'm going to check the dual valve springs and see if they need to be replaced or not.
Would you know what seat pressure and what open pressure they should have for a mushroom flat tappet P3614436 camshaft ?
Re: valve spring strength for mushroom flat tappet cam
[Re: docford]
#1526980
11/01/13 04:59 PM
11/01/13 04:59 PM
Posts: 2,666 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
That cam may have been listed in one of the old MP Hemi manuals. If it was they would have listed the proper MP spring. And it should have the springs specs in there but I'm not sure.
2011 Drag Pak Challenger
[Re: rickseeman]
#1526982
11/02/13 05:30 AM
11/02/13 05:30 AM
docford
Munich, Bavaria
The Chrysler HEMI Racing Manual only states a type and part number, but no specs.
It says "battleship" PN P3462887
[Re: dwayne welder]
#1526983
11/02/13 05:31 AM
11/02/13 05:31 AM
docford
Munich, Bavaria
Once you figure your camshaft spec's, and your retainer size, i would give PAC Racing Valve Springs a call!!! They make the springs in house!!! There are located in southfield, mi. 866-799-9417 Talk to Matt!!! I would NOT use those old spring's!!! You are just asking for proplem's!!!!!!!! Go TO www.RACINGSPRINGS.COM Good luck on your project!!
Thanks for the hint. We'll measure lift and duration and I'll give them a call
[Re: 23T Hemmee]
#1526985
11/03/13 07:35 PM
11/03/13 07:35 PM
docford
Munich, Bavaria
... I will say for right now, until I can find better info for you, do not use the battleship springs for any type of endurance engine, they will not live, period. They were drag only springs and were notorious for breaking even on the trailer if they weren't brought up to operating temps before putting any rpm's to them.
Thanks for the advice
[Re: docford]
#1526987
11/04/13 01:45 PM
11/04/13 01:45 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Doc, The STX-21 was used mostly on the short tracks, and would probably have a decent torque band for the type of racing you're doing. The bathtub intake was really not the greatest for up and down rpm changes and the short duration camshaft went a long way in keeping the engine cleaner without fouling plugs. One thing you might do, even if you don't run the original springs is go ahead and check the pressures and spring heights, if the pressures are within 3-5% across the board, that should give you a ball-park figure when ordering new ones. When you bought this engine, did it appear that it was ready to go, one way to tell, were the intake bolts allen-heads, and were they safety wired? Does it have the magnesium dry-sump pan or fab-steel? The mag pans were bad about corroding if they sat too long, just something to check.
[Re: docford]
#1526992
11/05/13 10:48 PM
11/05/13 10:48 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i dont know how high you plan to rev the motor, but that will have a big impact on the spring pressure requirement.
for an old school type cam like what you listed, i would probably start with something around 155 on the seat, and maybe 400-425 open. unless the motor has some rockers with higher than std ratios, i would expect that pressure would get you close to 7000rpm with that cam.
[Re: docford]
#1526996
12/21/13 04:26 PM
12/21/13 04:26 PM
Posts: 883 Affton MO
qwkmopardan
Affton MO
I found out that the installed camshaft is a Racer Brown STX-21.
That is a very good grind. My 383/449 with 915 heads made over 650 HP with the STX-21. 9.02 at 149 at 2500lbs. 145-150 seat and not more than 380 over the nose. If using new lifters I would send it back to Racer Brown for a regrind, about $75. 410-866-7660
[Re: qwkmopardan]
#1526997
12/22/13 08:07 AM
12/22/13 08:07 AM
docford
Munich, Bavaria
That is pretty close to what I did order. Here are my specs: ISKY-8205-SP Dual Valve Springs with damper 440 lbs./in. Rate
