Smlblk Cylhd CC's??
#1526615
10/31/13 05:35 PM
10/31/13 05:35 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Been playin' around with a syringe and a piece of plexyglass and checked a set of late 70's 596's and got "60cc's". Threw some 318 593's on the bench and got "69cc's".
I'm thinkin' the 360 heads were milled? Or does that sound normal.
I'll check some 308's and "X" heads tomorow.
Re: Smlblk Cylhd CC's??
[Re: Dean_Kuzluzski]
#1526617
10/31/13 07:21 PM
10/31/13 07:21 PM
RapidRobert
chrysler factory milling machines made straight marks on the surface finish & most all machine shop milling machines make curved marks so a visual may tell you something (but obviously not how much was taken off). As suggested try again & 60 is closed chambered territory. Holler how it goes
#1526619
11/01/13 07:18 PM
11/01/13 07:18 PM
RapidRobert
The 308's would be the best iron open chambered SB heads all else being equal as in what needs to be done to them compared to the others
