Largest rear tire/wheel combo on 64 Belvedere
#1526600
10/31/13 02:46 PM
10/31/13 02:46 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
What is the largest rear tire and wheel that will go on a 64 Plymouth Belvedere/Savoy without any modifications to the spring location,etc. ? Who makes the best Max Wedge scoop for one of these cars ?
Thanks for any help and / or pics
J.C. Childress
(434) 665-9541
Re: Largest rear tire/wheel combo on 64 Belvedere
[Re: mosweethemi]
#1526603
11/01/13 09:38 AM
11/01/13 09:38 AM
JC Childress
Big Island ,VA
I wonder if you could run a 10' wheel with the correct backspacing and 275/60 tire ? I mean would this work and you still be able to get the car low and nasty ?
J.C. Childress
(434) 665-9541
[Re: 64_Plymouth]
#1526605
11/01/13 05:50 PM
11/01/13 05:50 PM
JC Childress
Big Island ,VA
What size 10' wheel....as far as backspacing with leaf springs in factory location ?
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1526607
11/04/13 03:33 PM
11/04/13 03:33 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
I doubt that a 10" rim would clear without surgery. I run a unmodified 8" (4.312"bs more or less ) ramcharger wheel with 295/50's The side wall is less than an inch from the springs and I had to clearance the inner fenderwell. I also have a set of 275/60's on the same rim with pretty much the same results Randy
