Re: 440 stroker or not ? 1964 polara
[Re: AndyF]
#1526172
11/01/13 11:44 AM
11/01/13 11:44 AM
Posts: 3,698 jersey
Spaceman Spiff
jersey
Make sure you have a good fuel system to support it. No use building it if it's going to starve for fuel and burn a piston.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: 383man]
#1526176
11/01/13 02:29 PM
11/01/13 02:29 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
My '64 did not have headers...it had the later '68 to 70 Magnum manifolds and it was easier to change the plugs from under the car and if your not going to race it or show it and all you want to do is play with pony cars on back roads, why spend the money on the Max Wedge gear?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Twostick]
#1526178
11/01/13 03:48 PM
11/01/13 03:48 PM
Polarapete
Graham, WA
He may have been collecting parts for a long time, too. Here is a thought, build a stealthy stroker on a 383 block, use an aluminum intake painted engine color with an 800cfm Edelbrock (w/o E-brock sticker) single four barrel, stock looking painted air cleaner, Magnum manifolds to keep the noise down, serious hydraulic cam for power, hide the electronic ignition, keep your 14" tires & poverty caps and sell the Max Wedge stuff to put the money into the rebuild. That way you have reliability, long life, ease of maintenance... but what the heck do I know?!!! Please yourself.
[Re: Polarapete]
#1526179
11/01/13 05:34 PM
11/01/13 05:34 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
He did say he was going to use a crossram I believe. Even if he dont race some guys like the wow factor of the Max Wedge look when they pop the hood. I kinda went with the Max Wedge look but I could not really afford the crossram setup so I use a single carb intake as I figure I can go to the crossram later which I like that look. But it drives and runs so nice with the Indy dual plane intake and the 850 DP I use that for now I am sticking with that setup. I just tell people I got that rare factory option. After all the Nascar version of the Max Wedge had one carb. Ron
[Re: DoubleD]
#1526184
11/01/13 10:39 PM
11/01/13 10:39 PM
Posts: 10,636 Rittman Ohio
fourgearsavoy
Rittman Ohio
I say stroke it I love my 493 and it's even more fun with a manual transmission. Like Andy says you don't need a new flywheel if you order a six bolt crank. One thing I found too late with my Eagle crank was it wasn't drilled deep enough for my input shaft pilot. I had to whack about 1/2" off my brand new Richmond 5 speed input pilot Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: keith airgrabber]
#1526186
11/02/13 12:37 AM
11/02/13 12:37 AM
Polarapete
Graham, WA
I understand the problem now You are sick, but then so am I!!!! I think it is called Mopar Madness and it manifests itself in may ways, mostly in wanting the ability to demonstrate ridiculous horsepower to the unworthy to the detriment of tires and all things mechanical.
