'82 RC hubs #1525747
10/29/13 11:46 PM
10/29/13 11:46 PM
SD
Z
zrxkawboy Offline OP
Z
SD
My '82 RC still has the original auto hubs. Last winter it felt like they didn't engage a couple of times, so I bought some Superwinch manual hubs (400518). I am hearing conflicting advice about what is required to install them (replacing the auto hubs). Can someone set the record straight for me? I can pull the truck into the garage to do the work, but I don't want it in there taking up space for days if I tear into it and discover I need additional parts, special tool, etc. It would be nice to have everything lined up first. Thanks!
It's Swifty! Swifty, you toad sucker!
Re: '82 RC hubs [Re: zrxkawboy] #1525748
10/30/13 12:08 AM
10/30/13 12:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you read the hubs directions? If you bought them new there should be everything there along with the instructions. 30 minute job with basic tools.
Re: '82 RC hubs [Re: NITROUSN] #1525749
10/30/13 02:06 AM
10/30/13 02:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
and it might of been the CAD and not the hubs giving you trouble..
I am truckless..
Re: '82 RC hubs [Re: 340SHORTY] #1525750
10/30/13 02:14 AM
10/30/13 02:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
82 didn't have cad yet, just those auto locking hubs that should be easy swap to manuals.
Re: '82 RC hubs [Re: buildanother] #1525751
10/30/13 08:41 AM
10/30/13 08:41 AM
SD
Z
Z
SD
First of all, they came with NO directions. I went to their website and found an instruction sheet that was very basic and pretty much no help. I emailed Superwinch, and their response was "if it's a Dana 44, they'll work". All I was asking was if anything special was needed when converting from auto hubs. If there were instructions, and they told me what I needed, trust me, I wouldn't be wasting your time.
Let me re-phrase: Has anyone personally converted from auto hubs to manual, and can tell me what is involved? Thank you.
Re: '82 RC hubs [Re: zrxkawboy] #1525752
10/30/13 10:09 AM
10/30/13 10:09 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You pop the cover pull a snap ring(around axle shaft) and there should be a lock ring(outer part of internals)After those are removed you should be able to pull the auto hub parts out. Install the manual hubs insert outer lock ring and install snap ring(may have to push on axle from backside to have it prtrude enough to install snapring) Install cover
http://www.youtube.com/results?search_qu...ube.iE72SrqWYQM
Re: '82 RC hubs [Re: zrxkawboy] #1525753
10/30/13 10:17 AM
10/30/13 10:17 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its really pretty easy. Ive never converted but recently had my lockout pulled to replace wheel studs.
http://static.summitracing.com/global/images/instructions/wrn-61420c0-pn9790.pdf
http://ecx.images-amazon.com/images/I/61UYL0aIk1S.pdf
Re: '82 RC hubs [Re: zrxkawboy] #1525754
10/30/13 07:16 PM
10/30/13 07:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Whats wrong with these instructions?
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/17106.pdf
Re: '82 RC hubs *DELETED* [Re: NITROUSN] #1525755
10/30/13 11:25 PM
10/30/13 11:25 PM
SD
Z
Z
SD
Post deleted by not_a_charger
Re: '82 RC hubs [Re: zrxkawboy] #1525756
10/30/13 11:33 PM
10/30/13 11:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id like to see what you call an "Auto Hub"..
I am truckless..
Re: '82 RC hubs [Re: 340SHORTY] #1525757
10/30/13 11:43 PM
10/30/13 11:43 PM
SD
Z
Z
SD
Automatic hubs. Stock on my '82 RC. Engage when you shift into 4WD. Disengage when you shift into 2WD and then back up a few feet. From what I've been told, most were troublesome, and I'm in the minority to still have mine 30 years later. Like I said, I have never worked on them. When I first got the RC years ago, I knew a guy who was experienced with 4x4s, and I paid him to service the hubs. Now that they're acting up, and I don't know enough to service them properly, I'd just rather replace them with some simple, reliable manual hubs.
Re: '82 RC hubs [Re: zrxkawboy] #1525758
10/31/13 12:00 AM
10/31/13 12:00 AM
N
NITROUSN Offline
NITROUSN  Offline
N
EDIT
Re: '82 RC hubs *DELETED* [Re: NITROUSN] #1525759
10/31/13 12:09 AM
10/31/13 12:09 AM
SD
Z
Z
SD
Re: '82 RC hubs [Re: zrxkawboy] #1525760
10/31/13 08:39 AM
10/31/13 08:39 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I did them on my 84.I used Warns.Pretty straight forward and took about 45 minutes.Mine would unlock when plowing and backing up.Its been at least 20 years since I did them but it was easy.Rocky
Chrysler Firepower
Re: '82 RC hubs [Re: therocks] #1525761
10/31/13 09:33 AM
10/31/13 09:33 AM
SD
Z
Z
SD
Thanks for the words of experience, Rocky. I appreciate it.
