Installing mech. oil temp and mech. oil pressure gauge? #1524914
10/28/13 10:29 PM
10/28/13 10:29 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I'd like to install a mech. oil pressure and oil temp gauges. Could I run a t setup ? Or bad idea??
Or would drilling the oil pan for the fitting be a better idea? (oil temp)
It's on a /6 bracket engine if that makes any difference.
Re: Installing mech. oil temp and mech. oil pressure gauge? [Re: DusterKrazy] #1524915
10/28/13 11:28 PM
10/28/13 11:28 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i don't think a tee would be the best idea, having some oil movement around the bulb would give more accurate results.
Re: Installing mech. oil temp and mech. oil pressure gauge? [Re: DusterKrazy] #1524916
10/28/13 11:56 PM
10/28/13 11:56 PM
Az
Crizila Offline
Crizila  Offline
Az
Drill and tap the oil drain plug for the temp sensor.
Fastest 300
