Re: 505 dry sump headed to the dyno
[Re: AndyF]
#152454
11/17/08 04:27 PM
11/17/08 04:27 PM
Posts: 31,049 Oregon
AndyF
Close up of the ignition plate I built for the back of the motor. This makes it more self contained so we don't have to rewire the dyno cell. Thanks to the guys at MSD for the parts and tech support.
[Re: AndyF]
#152456
11/17/08 04:31 PM
11/17/08 04:31 PM
Posts: 5,080 organ
maximum entropy
organ
that's cool that your son is interested- mine couldn't care less. good luck with that motor, i hope you blow it up (the dyno)!
[Re: maximum entropy]
#152457
11/17/08 06:51 PM
11/17/08 06:51 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Is this a Flat cam, or a roller?..Cant wait for some details... I'm sure the boy will be pumping out Custom Billet peices before ya know it LOL That's good that he shows a interest in that stuff, I'm hoping for the same with Mine
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: AndyF]
#152459
11/17/08 07:20 PM
11/17/08 07:20 PM
what kind of testing will you be doing with the MSD? is it a comparison test against something else? tell us more about the "ratio testing" as well. what's that all about, just to see if they're really as advertised, or how much difference they make against something else?
[Re: AndyF]
#152461
11/17/08 09:59 PM
11/17/08 09:59 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
hate to ask about something so trivial, but whos vc gaskets are they? how do they hold up?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#152462
11/18/08 12:14 AM
11/18/08 12:14 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
moroso makes those gaskets. 93055 is the number. They will last forever unless you do something to them. They work best on machined surfaces and cast valve covers.
One more thing is i only use the center 4 bolts.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#152463
11/18/08 01:21 AM
11/18/08 01:21 AM
Posts: 659 Tampa Fl
kens avenger
mopar addict
mopar addict
Tampa Fl
you gonna dyno it with that oil pan.. looks like a wet sump pan to me..
Remember in here some don't think you should have a Opinion.. sad fact..
[Re: go green]
#152465
11/18/08 02:36 AM
11/18/08 02:36 AM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
505 Dry sump Pedestrian head engine why ?
With that engine combo Dry sump would never even be a consideration. Under 1000HP dry sump should not even be in the picture.
Thank you for the data but it does not seam realistic ??
HEY GO GREEN!!!! COOL CAR!!!
[Re: AndyF]
#152467
11/18/08 06:16 AM
11/18/08 06:16 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
No dry sump unless the motor makes more than 1000hp? That sounds like a really stupid rule you made up there.
Looking forward to the report on the dry sump. My bet is the gains will start small at 4500 to 5500 rpm, and be very substantial by 6500, awsome by 7500. One thing a dry sump will always have over any wet pan, oil control on the launch. Even the best wet pans have to lose some hp to windage in the first few feet due to extreme G forces at work. The faster the car, the worse it would be. No dyno can show that. It would be great to do back to back track tests to see how much of a difference there would be in each segment of the run.
[Re: AndyF]
#152468
11/18/08 11:17 AM
11/18/08 11:17 AM
Posts: 778 Sherwood park, Alberta.
go green
Sorry I didn't mean to ruffle you feathers .
Is this a test engine or a engine for your car ?
I will go back in your posts and get up to speed on what you are doing..
Engine looks great
[Re: AndyF]
#152470
11/18/08 04:54 PM
11/18/08 04:54 PM
I could do back to back wet-sump vs. dry sump testing but I probably won't bother since it takes a bunch of time and costs a bunch of money. Nobody is paying me for this testing so it all comes out of my pocket.
can you do this and sell it to the magazine to make your money back???????
