How do you remove plastic power steering pump pulley #1524583
10/28/13 06:18 AM
10/28/13 06:18 AM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
On a 98 Jeep 318? Is the bolt a reverse thread? I need to pull the pulley off to change the pump. Can't find anything specific ,quickly on the net. Moparts always comes thru. I'm actually using the pump for something else and need to change the pulley to a v belt so buying a pump with the same pulley isn't an option. From what I can tell this pump fits ALOT of cars and I think Speedway has a pulley I can use. Thanks.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: How do you remove plastic power steering pump pulley [Re: NAS Backyard] #1524584
10/28/13 11:55 AM
10/28/13 11:55 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I used a cheapy harbor freight power steering pulley puller kit, to do a plasticy pulley on a GM before, probably a similar setup?
(the threaded hole is to install the pulley)
