Page 2 of 3 1 2 3
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523669
10/27/13 09:43 PM
10/27/13 09:43 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Motor..
I drive it on the street the same as I run it at the track.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523670
10/27/13 09:44 PM
10/27/13 09:44 PM
Houston, Texas
Houston, Texas
Inside...full cage but hidden well...
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523671
10/27/13 11:15 PM
10/27/13 11:15 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
what was the fastest you went in the challenger?
what is the rear suspension on the dakota?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: T&T results with 13 lbs boost [Re: cheapstreetdustr] #1523672
10/28/13 11:39 AM
10/28/13 11:39 AM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
Way to go James That is really moving.
Re: T&T results with 13 lbs boost [Re: cheapstreetdustr] #1523673
10/28/13 11:56 AM
10/28/13 11:56 AM
Houston, Texas
Houston, Texas
Thanks Josh!
In the Chally, motor only I went 9.87 @ 137. Nitrous it went 9.28 @ 144
Rear is a ladder bar/coil over on drag radials.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523674
10/28/13 12:00 PM
10/28/13 12:00 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Nice job James, you're basically right where I hope to be shortly.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523675
10/28/13 01:17 PM
10/28/13 01:17 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
KOOL truck! i think i bought your challenger exhaust, 3.5 x pipe.
seems like a long time ago.....
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523676
10/28/13 01:54 PM
10/28/13 01:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
They are 83 lb injectors.
My goal when I started the build was a very streetable 10 second truck so I think I accomplished and exceeded that!
Thanks Ted!
I'll say! sounds like a very streetable NINE second truck!
**Photobucket sucks**
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523677
10/28/13 01:58 PM
10/28/13 01:58 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Dayamn... Trucks iz UGLY, but that ET is beautiful!
Re: T&T results with 13 lbs boost [Re: BradH] #1523678
10/28/13 09:50 PM
10/28/13 09:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What size is the motor?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: T&T results with 13 lbs boost [Re: 1967dartgt] #1523679
10/28/13 10:19 PM
10/28/13 10:19 PM
florida,usa
rdakota340 Offline
rdakota340  Offline
florida,usa
You are getting it tuned in congrats on the new times!
Turbos The Only Power Adder!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523680
10/28/13 10:36 PM
10/28/13 10:36 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks Josh!
How big of a shot of the juice in the chally?
Re: T&T results with 13 lbs boost [Re: racerx] #1523681
10/29/13 09:06 AM
10/29/13 09:06 AM
Houston, Texas
Houston, Texas
Motor is a stroked 5.2 for 389 cid.
I ran 160 shot on the Chally. I couldn't get it to hook on a bigger shot.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523682
10/29/13 10:06 AM
10/29/13 10:06 AM
an8sec70cuda Offline
VERY nice James!!!
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: T&T results with 13 lbs boost [Re: an8sec70cuda] #1523683
11/21/13 01:22 AM
11/21/13 01:22 AM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
Who,s turbo are you using? Any specs would be great.
Thanks jim
ACCELERATION SPECIALIST
Re: T&T results with 13 lbs boost [Re: voigtspeed] #1523684
11/21/13 02:16 AM
11/21/13 02:16 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
That's a very cool ride!!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523685
11/21/13 11:31 AM
11/21/13 11:31 AM
Az
Crizila Offline
Crizila  Offline
Az
Here are a few pics...
Awesome #'s James. . I'm hoping to break 130 this year and maybe low 10's.
Fastest 300
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523686
11/21/13 11:45 AM
11/21/13 11:45 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Awesome job!
That thing is officially flying!!!!!!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523687
11/21/13 07:46 PM
11/21/13 07:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That is so cool!
Re: T&T results with 13 lbs boost [Re: BSB67] #1523688
11/22/13 12:51 AM
11/22/13 12:51 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice pass! And nice Hot Rod to!
Page 2 of 3 1 2 3
