Re: T&T results with 13 lbs boost
[Re: TheOtherDodge]
#1523674
10/28/13 12:00 PM
10/28/13 12:00 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Nice job James, you're basically right where I hope to be shortly.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: TheOtherDodge]
#1523680
10/28/13 10:36 PM
10/28/13 10:36 PM
Posts: 4,076 Mo.
racerx
Mo.
Thanks Josh!
In the Chally, motor only I went 9.87 @ 137. Nitrous it went 9.28 @ 144
Rear is a ladder bar/coil over on drag radials.
How big of a shot of the juice in the chally?
[Re: TheOtherDodge]
#1523682
10/29/13 10:06 AM
10/29/13 10:06 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
VERY nice James!!!
