E-body Steering Columns and Lockout Linkage (4 Speed)?
#1523560
10/26/13 03:12 AM
10/26/13 03:12 AM
Posts: 401 California, USA
filmsurgeon
California, USA
The previous owner made a lot of changes to the '70 Challenger I now own. From the factory, it had a 383BB with a 3-SPD. This was changed to a SB with a 4-SPD. The '70 steering column was replaced with a '71-'74 version. That's just a couple of the MANY things that were changed as part of his resto-mod. Earlier this year, I removed the entire interior in an effort to either correct, reverse, and/or improve on some of the decisions that were made by the prior owner. My goal is to try and have the interior be (and/or look) as close as possible to a '70. That being said, pretty much the last thing I would need to do in order to accomplish this goal is swap out the later year column with a '70 version. One issue is the $$$ for a restored column (~$500+), and the reverse lock-out linkage assembly (~$250+). So, I'm looking at somewhere around $800. I could and would consider just staying with the simpler style later model column (it is in extremely nice/good condition). Another concern is, I have TTI headers, and I'm not sure if the lock-out linkage could be installed. Does anyone know if the TTI headers would interfere with the lock-out linkage assembly in any way? What would you folks do? Would you go the extra mile and $$$ for the '70 version column set-up, or keep it simple and stick with the later model column? Any opinions and advice will be much appreciated. Thanks.
Re: E-body Steering Columns and Lockout Linkage (4 Speed)?
[Re: AARCONV]
#1523563
10/26/13 09:22 PM
10/26/13 09:22 PM
filmsurgeon
California, USA
I would go with a 70..I am one of those guys that will notice that at a show is it power steering or manual steering? leave it for now until a nice lower price one comes up for sale..I can check my stock for which one you need
Thanks for the replies so far guys. I was at the Mopar Fall Fling Show today in Van Nuys, CA. There is always a swap meet area at the Spring and Fall Flings. Someone had a used '70 column w/o crush can (and other missing components) for manual steering that definitely needed to be restored (I have power steering, and could've swapped out the shaft from my column to work with his). Anyway, I asked "how much"?. He said, "$450. I said frustratingly, "I can buy a fully restored, COMPLETE column for $500; and walked away. What's up with these people?
[Re: Alaskan_TA]
#1523567
10/26/13 11:04 PM
10/26/13 11:04 PM
filmsurgeon
California, USA
It has nothing to do with your post, except that I cross referenced your VON & I had a VIN match for it. I have some history here about your car.
Thanks Barry. Didn't know this was you. Just sent you an email regarding my VIN search.
Thanks for your help.
[Re: filmsurgeon]
#1523569
11/05/13 08:31 PM
11/05/13 08:31 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I would tend to think that if the TTI can fit a column shifted automatic car, the "chances" might be favorable as the column shift auto linkage on an E body occupies the same location and configuration as the 4spd lock out set up?...I'd ask TTI if their headers are able to fit a column shifted smallblock E... I'll dig up some factory photos of both set ups... here's the 4spd interlock
[Re: DAYCLONA]
#1523571
11/05/13 09:28 PM
11/05/13 09:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
here's a floor shift auto/lock out 1970 E body, I would think if TTI's fit this mess, it should fit a 4spd interlock set up? something to quiz TTI on Mike
[Re: DAYCLONA]
#1523572
11/05/13 09:37 PM
11/05/13 09:37 PM
Posts: 1,567 Ky
jt4406
Ky
This pic shows the location of the Z bar and the lockout linkage (except the rod up to the column), without the column in place. 70 challenger 440 4 speed, stock exhaust manifold. Thought a shot from above brake m/cyl might help. jess
Yeah, it's hopped up to over 160...
